BT.com
Wishlist
Casio 2700 Lumens XGA Res DLP Technology Meeting Room Projector
Delivery
Standard Due date unavailable
Casio Core XJ-V1 DLP projector
DLP projector - High Definition 720p
White
Brightness
2700 lumens
Contrast Ratio
20000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Bulb type
Laser/LED
Bulb life cycle
Up to 20000 hour(s)
Video Input
RGB, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, PAL 60)
Video Modes
480p, 720p, 1080i, 480i, 576i, 576p
150 Watt
27 cm x 27 cm x 8.9 cm
2.8 kg
3 years warranty
DLP projector - HD 720p
Enclosure Colour
White
Projector
Brightness
2700 lumens
Contrast Ratio
20000:1
Image Size
76 cm - 762 cm
Projection Distance
0.83 m
Throw Ratio
1.54 - 1.71:1
Uniformity
72 %
Resolution
XGA - XGA (1024 x 768) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
4:3
Display Format
786,432 pixels
Colour Support
Bulb type
Laser/LED
Bulb life cycle
Up to 20000 hour(s)
Controls & Adjustments
Keystone correction
BrilliantColor, Image Freeze Function, Direct Power On, Direct Power Off, blank screen, Mercury-free illumination technology, Presentation Timer, rear projection
Lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
1.1x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-30 / +30
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI
Video Modes
1 x VGA - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB - 5 pin Micro-USB Type B
Wireless remote control
Security Features
Security lock slot (cable lock sold separately), password protection
150 Watt
Power Consumption Stand by
0.23 Watt
27 cm
27 cm
8.9 cm
2.8 kg
Limited warranty - 3 years - used for less than 12 hours per day , Limited warranty - lamp - 5 years / 10000 hours - used for less than 12 hours per day , Limited warranty - 2 years - used continuously (24 hours per day) , Limited warranty - lamp - 2 years / 6000 hours - used continuously (24 hours per day)
5 °C
35 °C
20 - 80% (non-condensing)
Sound Emission
37 dB
29 dB
Scroll to top
