BT.com
Wishlist
Caretech Telecare Fall Sensor
£107.30
  • Description
  • Specifications
  • Bundle deals
  • Accessories
  • Resources
  • Customer reviews
  • Buy used stock
  • Find similar
£107.30
Add to wishlist
Delivery
Standard Due date unavailable
  • Description
  • Specifications
  • Bundle deals
  • Accessories
  • Resources
  • Customer reviews
  • Buy used stock
  • Find similar
Pro5 Consortium Telecare Homepage
< Click here to return to Pro5 homepage
The fall sensor contains advanced electronics that record and process motion in multiple directions and speeds. When worn on the waist via the integral belt clip or a body belt the sensor can detect a change in angle, orientation and impact that can differentiate a fall from normal daily activity. Activation of a fall alarm occurs automatically when the wearer falls. When the fall sensor is connected to a carephone an alarm is transmitted automatically. A call can also be also transmitted via the emergency call button. Please note this device is compatible with CareTech systems only.
Important note: This sensor is only compatible with CareTech Carephones.
Scroll to top
