BT.com
Wishlist
Caretech Telecare Bed Sensor Complete
Caretech Telecare Bed Sensor...
£174.07
  • Description
  • Specifications
  • Bundle deals
  • Accessories
  • Resources
  • Customer reviews
  • Buy used stock
  • Find similar
£174.07
Add to wishlist
Delivery
Standard Due date unavailable
  • Description
  • Specifications
  • Bundle deals
  • Accessories
  • Resources
  • Customer reviews
  • Buy used stock
  • Find similar
Pro5 Consortium Telecare Homepage
< Click here to return to Pro5 homepage
Sense bed alarm consists of a sensor (bed mat) which connects to the sense MBox radio device. When the sensor activates an alarm is sent to carephone. The sense alarm provides automatic monitoring of battery and sensor function. On the main unit a simple function provides the ability to set different delay times before the alarm is sent for example if the client was to exit the bed and not return in 15 minutes. Time parameters can also be programmed so that the device will only work within certain times of the day for example between 9.00pm and 6.00am. Please note this device is compatible with CareTech systems only.
Important note: This sensor is only compatible with CareTech Carephones.
Scroll to top
