BT.com
Wishlist
Canon XF100 FHD CFx2 Professional Camcorder
Canon XF100 FHD CFx2 Professional...
£1,794.21
Hurry, only 1 left in stock!
£1,794.21
Add to wishlist
Delivery
Standard 1-3 working days
Compact in size, light weight and fully featured, the Canon XF100 Professional Camcorder can be tailored to fit a wide range of individual needs.
The XF100 utilizes Canon's XF codec - a file-based MPEG-2 compression with an MXF file wrapper that ensures the widest compatibility with existing industry infrastructure, metadata and non-linear editing (NLE) systems. The codec's 4:2:2 color sampling provides ultra-fine transitions in tone and color for maintaining the highest image quality needed for advanced post production processing.
Canon XF100 - camcorder - storage: flash card
Camcorder - 1080p - widescreen
Media Type
Flash card
Memory Card Slot
CompactFlash Card, SD card
Image Processor
DIGIC DV III
Sensor Resolution
2.37 MP
Effective Sensor Resolution
Video: 2.07 MP - Photo: 2.07 MP
Lens System
10 x zoom lens - 4.25 - 42.5 mm - f/1.8-2.8
Focus Adjustment
Automatic, manual
Min Focus Distance
60 cm
Digital Zoom
6 x
Image Stabiliser
Optical
Viewfinder
Electronic - 0.24" - colour - electronic - 16:9
Display
LCD display - 3.5"
Supported Battery
1 x Li-ion rechargeable battery ( included )
Interfaces Provided
Composite video/audio, HDMI, USB 2.0
13.9 cm x 26.8 cm x 19.1 cm
1.02 kg
Camcorder - 1080p
Camcorder Sensor Resolution
2.37 MP
Effective Video Resolution
2.07 MP
Effective Photo Resolution
2.07 MP
Widescreen Video Capture
Camcorder Media Type
Flash card
Optical Sensor Type
CMOS
Optical Sensor Size
1/3"
Optical Zoom
10 x
Digital Zoom
6 x
Image Processor
DIGIC DV III
Image Stabiliser
Optical
Face Detection
SMPTE Colour Bars, selectable frame rates, SMPTE Time Code, zebra pattern, waveform monitor
Auto Focus
TTL contrast detection
Digital Video Format
MPEG-2
Image Recording Format
JPEG
Audio Signal Format
PCM
Interfaces Provided
Exposure & White Balance
Min Illumination
0.7 lux
Exposure Modes
Programme, automatic, manual
White Balance
Custom, automatic, presets
White Balance Presets
Tungsten light, daylight, 2000K - 15000K (100K steps)
Max Shutter Speed
1/2000 sec
Min Shutter Speed
1/18 sec
Gain Selection
+12 dB, +18 dB, +3 dB, +6 dB, 0 dB, -3 dB, + 9 dB, +15 dB, +24 dB, +21 dB, +33 dB
Lens System
Focal Length Equivalent to 35mm Camera
30.4 - 304mm
Focus Adjustment
Automatic, manual
Min Focus Distance
60 cm
Macro Focus Range
2cm
Zoom Adjustment
Motorised drive
Lens Construction
10 groups / 12 elements
Filter Size
58 mm
Built-in neutral density filter
Additional Features
Low Lux / Night Mode
Additional Features
Digital noise reduction, interval shooting mode, takes photos while film recording, Pre-Rec function, face detection, 25p Cinema Mode
Viewfinder
Viewfinder Type
Electronic - electronic
Viewfinder Colour Support
Viewfinder Diagonal Size
0.24"
Viewfinder Resolution
260,000 pixels
Optical Viewfinder Field Coverage
100%
Optical Viewfinder Dioptric Correction Range
-5 to +2
Image Aspect Ratio
16:9
Tilting
Display
3.5" LCD display
Resolution
920,000 pixels
Display Form Factor
Rotating
Microphone
Microphone Operation Mode
Stereo
Microphone Features
Sensitivity control
Connector Type
1 x headphones , 1 x audio input , 1 x USB 2.0 , 1 x composite video/audio output , 1 x component video output , 1 x HDMI , 1 x DC power input , 1 x Control-L (LANC)
Lens hood, camcorder shoulder strap, lens cap, microphone holder, component video cable, IR remote control, power adapter with battery charger
Details
Memory / Storage
Memory Card Slot
Supported Memory Cards
CompactFlash
Image Storage
JPEG 1920 x 1280 , JPEG 1280 x 720
13.9 cm
26.8 cm
19.1 cm
1.02 kg
-5 °C
45 °C
Scroll to top
