Click to visit BT.com
BT.com
Wishlist
Canon Speedlite 430EX II - hot-shoe clip-on flash
Quicklinx: 577BWS00
Mfr#: 2805B003AA
Bringing a new level of versatility and capability to flash photography, the Speedlite 430EX II features a powerful flash with a fast recycling time in a compact, durable body. A one-touch quick-lock mechanism makes it easy to attach or detach the 430EX II from the camera and a metal foot has been added for strength and durability. Flash controls can now be set through the camera's LCD screen on compatible EOS Digital SLR cameras. The Speedlite 430EX II is also quieter, recycle time is 20% faster (as compared to the 430EX) and since it is compatible with Canon's wireless E-TTL, it can be used as an affordable "slave unit".
Camera Flash
Hot-shoe clip-on flash
7.2 cm x 10.1 cm x 12.2 cm
330 g
Guide Number (m / ISO 100)
43
Lens Coverage
24mm - 105mm
Supported Exposure Control
TTL, E-TTL, E-TTL II
Zoom
Automatic, manual
AF illuminator, illuminated LCD display, flash +/- compensation, wireless off-camera control, slave function
Required Battery
4 x battery - AA type
Canon XC10; EOS; New EOS; PowerShot G1, G10, G11, G12, G2, G2 Pro, G3, G5, G5 Pro, G6, G7, G9, Pro1, SX1 IS, SX10 IS, SX20 IS, SX30 IS, SX50 HS, SX60 HS
7.2 cm
10.1 cm
12.2 cm
330 g
Camera Flash
43
Lens Coverage
24mm - 105mm
Shooting Distance
0.7 m - 24.3 m
Horizontal Rotation Angle
+180 / -180
Zoom
Automatic, manual
Auto Shut-Off
Power Consumption
Recycling time - 0.1 - 3.7 sec / 1400 flash: - with 4 x AA type - Alkaline , Recycling time - 0.1 - 2 sec - with 4 x AA type - Nickel Metal Hydride
Required Battery
Canon XC10 , Canon EOS , Canon New EOS , Canon PowerShot G1, G10, G11, G12, G2, G2 Pro, G3, G5, G5 Pro, G6, G7, G9, Pro1, SX1 IS, SX10 IS, SX20 IS, SX30 IS, SX50 HS, SX60 HS
