Click to visit BT.com
BT.com
Wishlist
Canon PowerShot SX270 HS - 12.1 Mpix - 20 x optical zoom - blue
Quicklinx: 8LMNWS00
Mfr#: 8229B012AA
Essential accessories
Capture smooth movies and sharp shots with 20x zoom
The ideal compact for every family occasion, the PowerShot SX270 HS has a powerful 20x zoom to get you closer to the action, advanced Full HD movies and HS System with DIGIC 6 for exceptional results.
20x zoom, 25mm wide lens
HS System: 12.1 MP CMOS, DIGIC 6
Intelligent IS, Enhanced Dynamic IS
Full HD (60fps)
7.5 cm (3.0") PureColor II G LCD
Hybrid Auto; Smart Auto
Manual, Av and Tv modes
High-speed shooting
Optional 40m Waterproof Case
Fit more in the frame with 25mm or get extremely close to distant subjects with 20x optical zoom. Enjoy approx. double zoom power with ZoomPlus - an advanced zoom technology with more visible detail and sharpness than conventional digital zoom. The compact body means you can capture every precious memory wherever you go.
HS System excels in low light allowing you to capture the real atmosphere of the moment without flash or a tripod. Advanced DIGIC 6 processing and a high sensitivity 12.1 Megapixel CMOS sensor give exceptional image quality in all situations with up to ISO 6400.
Intelligent IS combats camera shake, so all your photos and videos are sharp and detailed even at full zoom or in low light. Enhanced Dynamic IS ensures spectacular steady and realistic movies by powerfully compensating for a much wider range of user movements.
Full HD movies (60fps)
Use the movie button to instantly record smooth, stunningly realistic Full HD (1080p) movies at 60fps in stereo with optical zoom. MP4 support allows easy playback and sharing on portable devices.
A large, durable, high quality LCD screen with excellent visibility offers effortless menu navigation, lets you frame and view shots with ease and makes sharing them a pleasure.
Hybrid Auto, Smart Auto
Effortlessly shoot great photos or movies with Smart Auto, which selects optimal settings from 58 variables (21 in movies). Hybrid Auto lets you take photos with Smart Auto and also captures a 4 second movie clip before each shot - combining them into a fun HD (720p) movie.
Experiment with different effects using Manual modes (Tv, Av and M), which give you creative control over shutter speed and aperture.
High-speed shooting
Capture stunning fast action with High-speed Burst or slow it down spectacularly with Super Slow Motion Movie.
Canon PowerShot SX270 HS - digital camera
Digital camera - compact
Memory Card Slot
SD card
Image Processor
DIGIC 6
Sensor Resolution
12.1 Megapixel
Max Video Resolution
1920 x 1080
Lens System
Zoom lens - 20 x zoom - 4.5 - 90 mm - f/3.5-6.8
Focus Adjustment
Automatic, manual
Min Focus Distance
5 cm
Digital Zoom
4 x
Image Stabiliser
Optical
Camera Flash
Pop-up flash
Display
LCD display - 3"
Supported Battery
1 x Canon NB-6L Li-ion rechargeable battery - 1000 mAh ( included )
Interfaces Provided
Composite video/audio, HDMI, USB 2.0
Blue
10.64 cm x 3.26 cm x 6.11 cm
227 g
Enclosure Colour
Blue
Sensor Resolution
12.1 Megapixel
Optical Sensor Type
BSI-CMOS
Total Pixels
12,800,000 pixels
Effective Sensor Resolution
12,100,000 pixels
Optical Sensor Size
1/2.3"
ISO (Max)
6400
Optical Zoom
20 x
Digital Zoom
4 x
Image Processor
DIGIC 6
Image Stabiliser
Optical
Face Detection
Print Standard
Direct print, DPOF support, Exif Print support, PictBridge support
Auto Focus
TTL contrast detection
AE/AF Control
Subject-tracking AF
Face Detection
Face Detection AF/AE/FE/WB, Face Detection Self-timer, Wink Self-timer, Smile Shutter, face ID
Digital Video Format
H.264, MOV
Image Recording Format
JPEG
1920 x 1080
Interfaces Provided
Exposure & White Balance
Light Sensitivity
ISO 100, ISO 800, ISO 400, ISO 200, ISO 80, ISO 1600, ISO 6400, ISO 3200, ISO auto
Exposure Metering
Evaluative, centre-weighted, spot
Exposure Modes
Programme, automatic, manual, aperture-priority, shutter-priority
Shooting Programs
Portrait mode, fireworks, Underwater, sports mode, snow, handheld night shot, smart shutter, movie digest, hi-speed burst HQ, discreet
Special Effects
Black & White, Sepia, Neutral, Vivid, Custom Effect, fisheye, soft focus, monochrome, Lighter Skin Tone, Darker Skin Tone, Vivid Green, vivid blue, Vivid Red, miniature, Toy camera, Posterisation, Super Vivid
White Balance
Custom, automatic, presets
White Balance Presets
Fluorescent, cloudy, tungsten light, daylight, fluorescent light (daylight), Underwater
Max Shutter Speed
1/3200 sec
Min Shutter Speed
15 sec
Exposure Compensation
±2 EV range, in 1/3 EV steps
Lens System
Focal Length Equivalent to 35mm Camera
25 - 500mm
Focus Adjustment
Automatic, manual
Min Focus Distance
5 cm
Macro Focus Range
5-50cm
Zoom Adjustment
Motorised drive
Lens Construction
10 groups / 12 elements
UD glass, built-in lens shield, aspherical lens
Camera Flash
Camera Flash
Pop-up flash
Flash Modes
Fill-in mode, slow synchro, auto mode, flash OFF mode, red-eye reduction
AF illuminator, flash +/- compensation
Effective Flash Range
0.5 m - 3.5 m ( wide lens ) , 1 m - 2 m ( tele lens )
Additional Features
Continuous Shooting Speed
1 frame per second, 3.8 frames per second, 5.1 frames per second for 7 frames, 14 frames per second for 7 frames
Self Timer Delay
10 sec, 2sec
Additional Features
RGB primary colour filter, digital image rotation, camera orientation detection, histogram display, AE lock, AF lock, FE lock, in-camera red-eye removal, cropping an image, resizing an image, i-Contrast (Intelligent Contrast Correction) system, digital tele-converter, safety zoom, Smart Flash Exposure, HS System, Smart AUTO, Hybrid Auto
Display
3" LCD display
Resolution
461,000 pixels
Display Form Factor
Built-in
Display Features
Display brightness control
Microphone
Microphone Operation Mode
Stereo
Microphone Features
Wind noise reduction
Connector Type
1 x USB 2.0 , 1 x composite video/audio output , 1 x HDMI output
Software
Software
Canon PhotoStitch, Canon ImageBrowser
Battery charger, wrist strap
Battery Type
Canon NB-6L
Details
Battery Life Details
Photo shooting - 230 shots , Photo shooting - 260 shots ( ECO mode ) , Playback - 3.5 hours
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card
Image Storage
JPEG 4000 x 3000 , JPEG 4000 x 2248 , JPEG 4000 x 2664 , JPEG 2816 x 1584 , JPEG 2816 x 2112 , JPEG 2816 x 1880 , JPEG 1920 x 1080 , JPEG 1600 x 1200 , JPEG 1600 x 1064 , JPEG 640 x 480 , JPEG 640 x 360 , JPEG 640 x 424 , JPEG 2992 x 2992 , JPEG 2112 x 2112 , JPEG 1200 x 1200 , JPEG 480 x 480
Video Capture
H.264 - 1920 x 1080 - 60 fps , H.264 - 1280 x 720 - 30 fps , H.264 - 640 x 480 - 30 fps , H.264 - 640 x 480 - 120 fps , H.264 - 320 x 240 - 240 fps , H.264 - 1920 x 1080 - 30 fps
10.64 cm
3.26 cm
6.11 cm
227 g
10 - 90%
