Click to visit BT.com
BT.com
Wishlist
Canon PIXMA MX925 Colour Inkjet Multifunction Printer
Quicklinx: 8JDRWS00
Mfr#: 6992B008AA
Functionality: Scanner
Output Type: Colour
Wireless Capability: Wireless
Technology: Ink-jet
29 in stock
£128.17
Essential accessories
High productivity, powerful Office All-In-One with Wi-Fi and XXL ink option
Powerful and productive 5-ink All-In-One offering XL and XXL ink options, Wi-Fi, Ethernet and 35-page 2-sided ADF. Advanced media handling with 250-sheet paper tray, 2-sided printing and Direct Disc Print.
  • Powerful and productive Office All-In-One
  • 35-page 2-sided Auto Document Feeder for scanning, copying and faxing
  • Superior prints using 5 individual ink system with optional XL capacity ink tanks
  • Print up to 1000 monochrome pages with optional XXL monochrome ink
  • Convenient, high-capacity 250-sheet paper tray
  • Large, user-friendly 7.5cm (3.0") colour TFT display with Dual Function Panel
  • Fast printing with A4 ISO ESAT 15 ipm mono/10 ipm colour
  • Print from, and scan to, smartphones/tablets. Apple AirPrint supported
  • Google Cloud Print support and internet printing using PIXMA Cloud Link
  • Advanced media handling with Direct Disc Print and 2-sided printing
Powerful and productive All-In-One
This premium, network-ready All-In-One delivers high productivity that everyone can share. Wi-Fi and Ethernet connectivity enable you to print, scan, copy and fax from virtually anywhere in the office or at home. Apple AirPrint support lets you print directly from iPad and iPhone.
Automatically scan, copy or fax large double-sided documents using the fully-integrated 35-page 2-sided Automatic Document Feeder. A high capacity 250-sheet tray means you spend less time loading paper, while automatic 2-sided printing reduces the amount of paper you use. Double front paper cassettes mean you can conveniently have two media types loaded at once, plus you can print directly onto printable discs using Direct Disc Print.
Economical, single ink tanks
For greater economy, this All-In-One features 5 single inks, so you only need to change the colour that runs out - making printing more efficient. Optional cost effective XL and XXL inks allow for more pages to be printed than a standard ink, so need replacing less frequently - ideal if you print a lot. XXL cartridge can print up to 1000 pages.
High quality, fast performance
Canon's FINE technology, with minimum 1pl ink droplets, delivers up to 9600dpi print resolution for amazingly detailed colour photos and images. Enjoy high print speeds of 15ipm mono or 10ipm colour. Print a photo-lab quality 10x15 cm borderless photo in approx. 21 seconds or copy an A4 page in just 12 seconds.
PIXMA Cloud Link
Print Google Docs, Gmails, photos and PDF attachments from virtually anywhere using Google Cloud Print. Produce calendars, download stationery and other templates direct from the PIXMA Cloud. Get more from your printer and print directly from the Internet. Print photos in seconds from CANON iMAGE GATEWAY or Google's Picasa online albums without a PC.
Smartphone and tablet ready
Canon's Easy-PhotoPrint app provides the flexibility to print from, or even scan to, your mobile devices wherever you are in the office. With Apple AirPrint support, you can also print photos, emails, web pages and other documents direct from your iPhone, iPad and iPod touch.
User-friendly operation
A large 7.5cm colour TFT display makes it easy to view selected functions and preview images. The Dual Function Panel features LED-lit dual-purpose keys. These keys change appearance according to the mode selected, simplifying feature navigation.
Canon PIXMA MX925 - multifunction printer ( colour )
Fax Type
Super G3 - plain paper
Printing Technology
Ink-jet ( colour )
Inkjet Technology
Canon FINE (Full-lithography inkjet Nozzle Engineering) - 5-ink
Max Copying Speed
8.4 ppm (colour)
Max Printing Speed
Up to 15 ipm (mono) / up to 10 ipm (colour)
Max Printing Resolution
9600 x 2400 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JPEG
Fax Resolutions
300 x 300 dpi, 200 x 200 dpi
Scanning
2400 x 4800 dpi
Display
3"
Original Size
A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, photo paper, printable CD/DVD/BD disk
Standard Media Capacity
250 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
PC Connection Availability
PC Connection
USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
PIXMA Cloud Link, Google Cloud Print ready, Fast Front
AC 120/230 V ( 50/60Hz )
49.1 cm x 39.6 cm x 23.1 cm
11.7 kg
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
Display Diagonal Size
3"
PC Connection
AirPrint Enabled
Supported Flash Memory
USB flash drive
Copying
Max Copying Speed
8.4 ppm (colour)
Grey Scale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Copying Features
BorderFree, fit to page, Preset Copy Ratios
Printing
Inkjet Technology
Max Printing Speed
Ink Cartridge Configuration
5 individual ink tanks
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black, pigment black
5-ink
Minimum Ink Droplet Size
1 pl
Ink Type
Canon ChromaLife100+
Automatic Duplexing
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
2400 x 4800 dpi
Grey Scale Depth
8 bit
Colour Depth
24 bit
Colour Depth (Internal)
48 bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JPEG
Fax Resolutions
Total Memory Capacity
Up to 250 pages
Fax Machine Features
Error Correction Mode (ECM)
Speed Dialing
100 station(s)
Telephone / Fax Switch
Activity report, answering machine interface
Document & Media Handling
Max Original Size
Original Type
Sheets
35 sheets
Max Media Size
Legal
Min Media Weight
64 g/m²
Max Media Weight
300 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm)
Borderless Photo Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
250 sheets
ADF - 35 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) , Input tray - 250 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) , Input tray - 20 sheets - 130 x 180 mm , CD/DVD/BD tray
Speed Details
Printing : up to 15 ipm - B/W , Printing : up to 10 ipm - colour , Copying : up to 8.4 ipm - colour , Printing : 21 sec ( 10 x 15 cm (4"x6") ) - photo
1 x USB 2.0 - 4 PIN USB Type B , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45
Security Protocols & Features
WEP, WPA-PSK, WPA2-PSK
Operating System Support
MS Windows XP, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows Vista (64-bit versions), Apple Mac OS X 10.6.8 or later, Windows 8, Windows RT, Windows 8 64-bit
Software Included
Drivers & Utilities, Canon Easy-WebPrint EX, Canon Full HD Movie Print, Canon Creative Park Premium, Canon My Image Garden
17 Watt
Power Consumption Standby
1 Watt
Power Consumption Sleep
0.4 Watt
Direct Printing Specifications
PictBridge
First Copy Out Time Colour
12 sec
Phone cable
Consumables Included
1 x ink tank ( black ) , 1 x ink tank ( cyan ) , 1 x ink tank ( magenta ) , 1 x ink tank ( yellow ) , 1 x ink tank ( pigmented black )
49.1 cm
39.6 cm
23.1 cm
11.7 kg
Sound Emission
44 dBA (operating)
5 °C
35 °C
10 - 90% (non-condensing)
Canon PIXMA MX925 Colour Inkjet Multifunction Printer Bundle deal on Canon PIXMA MX925 Colour Inkjet Multifunction Printer
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £14.98 | while stocks last
£138.16
saving £4.99
8JDR Canon GP-501 Glossy Photo Paper - 100 Sheets In Stock £16.72
8JDR Canon PGI-550PGBK XL - Pigment Black - Ink Cartridge In Stock £11.82
8JDR Canon CLI-551 XL Black Ink Cartridge In Stock £11.19
8JDR Canon CLI-551 XL Cyan Ink Cartridge In Stock £11.19
8JDR Canon CLI-551 XL Magenta Ink Cartridge In Stock £11.19
8JDR Canon CLI-551 XL Yellow Ink Cartridge In Stock £11.06
8JDR Canon CLI-551 XL Grey High Yield Ink Tank In Stock £11.35
8JDR Canon CLI-551 Cyan Ink Tank In Stock £8.89
8JDR Canon CLI-551 Yellow Ink Tank In Stock £8.83
8JDR Canon CLI-551 Magenta Ink Tank In Stock £8.83
Output Type: Colour
Technology: Ink-jet
Max Print Speed: [N/A]
Brand: Canon
Price Range Inc VAT: 100 - 150
