BT.com
Wishlist
Canon PIXMA MX455 - Inkjet - Colour - All-in-One - WiFi
Delivery
Standard Due date unavailable
Stylish Office All-In-One with fully-integrated ADF and Wi-Fi
Stylish and compact with Wi-Fi, this Office All-In-One delivers multipage copying and scanning with integrated 30-page ADF. Easily print from, and scan to, your smartphone or tablet.
Compact and stylish Office All-In-One with ADF and Wi-Fi
Print more for less with XL FINE cartridges
Fully-integrated 30-page Auto Document Feeder for quick scanning, copying and faxing
Superior-quality prints with up to 4800dpi and FINE cartridge technology
Print from, and scan to, popular smartphones/tablets. Apple AirPrint support
Directly scan PDF and JPEG files to USB memory stick
A4 print speed ISO ESAT 9.7 ipm mono/5.5 ipm colour. A4 colour copy in approx. 21 seconds
Create PDF files; extract text from PDF or JPEG files using My Image Garden software
Scan to your Evernote or Dropbox cloud service
Intelligent web printing with Easy-WebPrint EX
Compact, Wi-Fi All-In-One
This compact All-In-One, with sleek all-black design and built in Wi-Fi connectivity is perfectly placed to help you print, copy, scan and fax - from wherever suits you best. It also features a FastFront design to simplify paper loading and ink replacement - making it the ideal printer if you're looking for everyday functionality at home or in a small office.
Smartphone and tablet ready
Canon's Easy-PhotoPrint app provides the flexibility to print from, or even scan to, your mobile devices, wherever you are in the home. With Apple AirPrint support, you can also print photos, emails, web pages and other documents direct from your Apple iPhone, iPad and iPod touch.
Save money on ink
Print more for less with XL FINE cartridges, which deliver up to 50% savings per page compared to their standard equivalents. XL cartridges also deliver significantly more pages and last longer between ink replacements - ideal if you print frequently.
Fast, multipage copy, scan and fax
For maximum productivity, a fully-integrated 30-sheet Automatic Document Feeder makes scanning, copying or faxing of large documents easy and fast.
High-quality prints
Canon's FINE ink technology, with microscopic ink droplets plus a resolution of up to 4800 x 1200 dpi, ensures quality printing every time. From vivid and glossy graphics to business documents of outstanding clarity, this printer is ideal for use at home or in a small office.
Quick printing and copying
Enjoy A4 ISO ESAT print speeds of 9.7 ipm mono or 5.5 ipm colour and a 10x15cm borderless photo in approx. 46 seconds, while an A4 colour page copies in around 21 seconds. Quick Start also means this All-In-One is ready to go seconds after switching on.
Scan to the cloud or USB
You can easily scan documents directly to your Evernote or Dropbox cloud service giving you access to them from almost any mobile device. A front USB port also lets you scan to a USB memory stick, without the need for a PC.
Smart web printing
Intelligently print from the Internet with minimum wastage. Using Easy-WebPrint EX, easily combine content from several websites and print as one document.
Canon PIXMA MX455 - multifunction printer ( colour )
Fax / copier / printer / scanner
Fax Type
Super G3 - plain paper
Printing Technology
Ink-jet ( colour )
Inkjet Technology
Canon FINE (Full-lithography inkjet Nozzle Engineering) - 4-ink
Max Copying Speed
4.7 ppm (colour)
Max Printing Speed
Up to 9.7 ipm (mono) / up to 5.5 ipm (colour)
Max Printing Resolution
4800 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JPEG
Fax Resolutions
300 x 300 dpi, 200 x 200 dpi
Scanning
1200 x 2400 dpi
Original Size
A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
30 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, photo paper
Standard Media Capacity
100 sheets
PC Connection Availability
PC Connection
USB 2.0, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
PIXMA Cloud Link, Google Cloud Print ready, Fast Front
AC 110/230 V ( 50/60Hz )
45.8 cm x 38.5 cm x 20 cm
8.4 kg
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
PC Connection
AirPrint Enabled
Supported Flash Memory
USB flash drive
Copying
Max Copying Speed
4.7 ppm (colour)
Grey Scale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
BorderFree, fit to page
Printing
Inkjet Technology
Max Printing Speed
Ink Cartridge Configuration
1 black cartridge, 1 colour cartridge (cyan, magenta, yellow)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Minimum Ink Droplet Size
2 pl
Ink Type
Canon ChromaLife100
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Grey Scale Depth
8 bit
Colour Depth
24 bit
Colour Depth (Internal)
48 bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JPEG
Fax Resolutions
Total Memory Capacity
Up to 50 pages
Fax Machine Features
Error Correction Mode (ECM)
Activity report, answering machine interface
Document & Media Handling
Max Original Size
Original Type
Sheets
30 sheets
Max Media Size
Legal
Min Media Weight
64 g/m²
Max Media Weight
300 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm)
Borderless Photo Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
100 sheets
ADF - 30 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) , Input tray - 100 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm)
Speed Details
Printing: up to 9.7 ipm - B/W , Printing: up to 5.5 ipm - colour , Copying: up to 4.7 ipm - colour , Printing: 46 sec ( 10 x 15 cm (4"x6") ) - photo
1 x USB 2.0 - 4 PIN USB Type B , 1 x USB host - 4 pin USB Type A
Security Protocols & Features
WEP, WPA-PSK, WPA2-PSK
Operating System Support
MS Windows XP, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows Vista (64-bit versions), Apple Mac OS X 10.6.8 or later, Windows 8, Windows RT, Windows 8 64-bit
Software Included
Drivers & Utilities, Canon Easy-WebPrint EX, Canon Full HD Movie Print, Canon Creative Park Premium, Canon My Image Garden
18 Watt
Power Consumption Standby
1.1 Watt
Power Consumption Sleep
0.3 Watt
Direct Printing Specifications
PictBridge
First Copy Out Time Colour
21 sec
USB cable, phone cable
Consumables Included
1 x Cartridge ( black ) , 1 x Cartridge ( colour )
45.8 cm
38.5 cm
20 cm
8.4 kg
Sound Emission
42.5 dBA (operating)
5 °C
35 °C
10 - 90% (non-condensing)
Accessories
£27.27
£12.79
£16.42
£19.16
£18.86
Scroll to top
