BT.com
Wishlist
Canon PIXMA MX375 - All-in-One ( fax / copier / printer / scanner ) ( colour )
Delivery
Standard Due date unavailable
The All-In-One that handles everything with ease
PIXMA MX375 is an All-In-One with fax that delivers quality prints. With a built-in 30-sheet ADF, full suite of software it's both versatile and affordable. Compact design with FastFront.
Quality results for home and office
This affordable All-In-One lets you copy, print, scan and fax with ease. Canon's FINE ink technology, with microscopic ink droplets, plus a resolution of 4800 x 1200 dpi ensures quality printing everytime. From vivid and glossy graphics to business documents of outstanding clarity, the printer is ideal for use at home or in a small office.
Productivity booster
For maximum productivity, a fully-integrated 30-sheet Automatic Document Feeder makes scanning, copying or faxing of large documents easy and fast.
Do more for less, faster
Enjoy print speeds, of 8.7 ipm in mono or 5.0 ipm in colour. A 10x15 cm borderless photo is printed in approximately 46 seconds, while an A4 page copies in just 23 seconds. Canon's Dual Colour Gamut Processing technology enables great quality photocopying with no waiting around.
Value for money
For further savings you can print more for less, with the high yield Canon XL cartridges, which offer 50% lower cost per page.
Space-saving design and easy-to-use
The compact FastFront design means paper and ink cartridges can be loaded from the front of the printer - making it easier to fit into a busy work space. Quick Start functionality means there is no need to wait for the printer to `warm up'. Operation is almost instantaneous from the moment the power is switched on, ensuring that the user can perform actions almost straight away.
Fast faxing
Super G3 faxing is fast and reliable. The PIXMA MX375 can send faxes directly from the PC without printing the document first. For advanced security you can prevent users accidentally sending faxes to the wrong number.
Intelligent software
Take control of your web printing, easily combining content from several websites with Easy-WebPrint EX. Automatically optimising the quality and legibility of scanned documents is simple with Auto Document Fix. For additional security MP Navigator EX adds passwords to PDFs that restrict who can edit or print sensitive documents.
All-In-One with fax and 30-sheet ADF
Up to 4800dpi, min. 2pl quality
ISO ESAT 8.7 ipm mono/5.0 ipm colour
ISO A4 Copy: 23 seconds
Easy-WebPrint EX for efficient web printing
Auto Document Fix enhancement
Full HD Movie Print
Canon PIXMA MX375 - multifunction printer ( colour )
Fax / copier / printer / scanner
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
Ink-jet ( colour )
Inkjet Technology
Canon FINE (Full-lithography inkjet Nozzle Engineering) - 4-ink
Max Copying Speed
3.4 ppm (colour)
Max Printing Speed
Up to 8.7 ipm (mono) / up to 5 ipm (colour)
Max Printing Resolution
4800 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JPEG
Fax Resolutions
300 x 300 dpi, 200 x 200 dpi
Scanning
1200 x 2400 dpi
Original Size
A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
30 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, photo paper
Standard Media Capacity
100 sheets
PC Connection Availability
PC Connection
USB 2.0
AC 110/230 V ( 50/60Hz )
45.8 cm x 38.5 cm x 20 cm
8.4 kg
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Ink-jet - colour - photo
PC Connection
USB 2.0
Copying
Max Copying Speed
3.4 ppm (colour)
Grey Scale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
2 on 1, BorderFree, 4 on 1, fit to page, Preset Copy Ratios, Frame Erase Copy, collation copy
Printing
Inkjet Technology
Max Printing Speed
4-ink
Minimum Ink Droplet Size
2 pl
Ink Type
Canon ChromaLife100
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Grey Scale Depth
8 bit
Colour Depth
24 bit
Colour Depth (Internal)
48 bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JPEG
Fax Resolutions
Total Memory Capacity
Up to 50 pages
Fax Machine Features
Error Correction Mode (ECM)
Speed Dialing
20 station(s)
Telephone / Fax Switch
Activity report, automatic redialing, answering machine interface, group dialling, remote reception, Dual Access
Document & Media Handling
Max Original Size
Original Type
Sheets
30 sheets
Max Media Size
Legal
Min Media Weight
64 g/m²
Max Media Weight
300 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm)
Borderless Photo Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
100 sheets
ADF - 30 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) , Input tray - 100 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm)
Speed Details
Printing: up to 8.7 ipm - B/W , Printing: up to 5 ipm - colour , Copying: up to 3.4 ipm - colour , Printing: 46 sec ( 10 x 15 cm (4"x6") ) - photo
1 x USB 2.0
Operating System Support
MS Windows 7, MS Windows XP SP3, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows Vista (64-bit versions), MS Windows XP SP2, Apple Mac OS X 10.5.8 - 10.7
Software Included
Drivers & Utilities, Canon Easy-WebPrint EX, Fax Speed Dial Utility, Canon Easy-PhotoPrint EX, Canon MP Navigator EX, Canon Solution Menu EX
14 Watt
Power Consumption Standby
1.6 Watt
Power Consumption Sleep
0.4 Watt
First Copy Out Time Colour
23 sec
Consumables Included
1 x Cartridge ( black ) - up to 180 pages - Canon PG-540 , 1 x Cartridge ( colour ) - up to 180 pages - Canon CL-541
45.8 cm
38.5 cm
20 cm
8.4 kg
Sound Emission
42.5 dB (operating)
5 °C
35 °C
10 - 90%
Accessories
£27.48
£12.96
£16.39
£19.11
£19.11
Scroll to top
