BT.com
Wishlist
Canon PIXMA MG6350 Colour Inkjet Multifunction Printer
Delivery
Standard Due date unavailable
Premium 6-ink All-in-One with touch screen operation, Internet and mobile printing.
Premium 6-ink Photo All-in-One, with stylish low-profile design available in black or white. Easy to use with intuitive touch panel and colour touch screen, it offers mobile and Internet printing.
Internet printing with PIXMA Cloud Link
Intuitive touch panel with 8.8cm touch screen
Low-profile, stylish design in black or white
Mobile printing & Apple AirPrint
My Image Garden software
Direct Disc Print & Auto Duplex
Premium Performance
Photo All-in-One offering exceptional quality printing, scanning and copying. Ideal for the photo enthusiast, the FINE print head with 1pl, delivers 9600dpi print resolution for professional photos at home. The 6-ink system includes grey for richer colour photos and stunning mono prints. A 10x15cm photo can be produced fast, in 21 seconds while the ISO ESAT print speed of 15ipm mono and 10ipm colour ensures rapid document printing.
Internet printing
With PIXMA Cloud Link you can print directly from the Internet. Using the printer screen, you can browse and print your photos from online albums at CANON iMAGE GATEWAY and Google's Picasa, or access on demand calendars, stationery and other templates from the Cloud. Print from virtually anywhere using Google Cloud Print, including emails, photo and PDF attachments, and Google Docs from your Gmail account.
Touch operation
Integrated in the top of the printer, the stunning-looking Intelligent Touch System has no physical buttons, providing light-guided touch operation instead. For an even smoother user experience, it is now combined with a large touch screen.
Smartphone and Tablet ready
Print from and even scan to your smartphone and tablet from around the house with Canon's Easy-PhotoPrint App. With Apple AirPrint support you can also print photos, emails, web pages and other documents wirelessly from your iPhone, iPad and iPod touch.
Creative software
Experience the full potential of your PIXMA with My Image Garden, which offers easy photo printing, scanning and access to online services. Its photo organising capabilities, including face recognition, enable you to discover long lost photos and combine them in creative ways for printing. The Print Your Days app lets you print photos direct from Facebook.
Save paper and energy
Double-sided printing reduces the amount of paper you use and creates professional looking documents. For your convenience, Auto Power On automatically turns the printer on when you start printing and Auto Power Off switches the printer off if not used for a set time - saving you energy.
Save money on ink
With individual ink tanks you only change the colour that has run out making printing more efficient. Now you can print more for less with optional high yield XL inks. Each individual XL ink prints up to 2.2 times more pages than a standard one - ideal if you print a lot.
Canon PIXMA MG6350 - multifunction printer ( colour )
Printer / copier / scanner
Copier Type
Digital
Printing Technology
Ink-jet ( colour )
Inkjet Technology
Canon FINE (Full-lithography inkjet Nozzle Engineering) - 6-ink
Max Copying Speed
7.7 ppm (colour)
Max Printing Speed
Up to 15 ipm (mono) / up to 10 ipm (colour)
Max Printing Resolution
9600 x 2400 dpi (colour)
Scanning
2400 x 4800 dpi
Display
3.5"
Original Size
A4 (210 x 297 mm), Letter A (216 x 279 mm) (max)
Original Type
Sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, photo paper, printable CD/DVD/BD disk
Standard Media Capacity
125 sheets
Automatic Duplexing
Yes (printing)
PC Connection Availability
PC Connection
USB 2.0, LAN, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
Print from memory card, scan to folder, scan to network, Auto Photo Fix II, PIXMA Cloud Link, Google Cloud Print ready, red-eye correction
AC 110/230 V ( 50/60Hz )
46.6 cm x 36.9 cm x 14.8 cm
8.4 kg
Copier Type
Digital
Printing Technology
Ink-jet - colour - photo
Display Diagonal Size
3.5"
Display Features
Touch screen, Intelligent Touch System
PC Connection
AirPrint Enabled
Supported Flash Memory
CompactFlash, SD Memory Card, MultiMediaCard, Memory Stick Duo, IBM Microdrive, MultiMediaCardplus, Memory Stick PRO Duo, SDHC Memory Card
Copying
Max Copying Speed
7.7 ppm (colour)
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
2 on 1, BorderFree, 4 on 1, fit to page, Frame Erase Copy, collation copy
Printing
Inkjet Technology
Max Printing Speed
Ink Cartridge Configuration
6 individual ink tanks
6-ink
Minimum Ink Droplet Size
1 pl
Ink Type
Canon ChromaLife100+
Automatic Duplexing
Scanning
Scan Element
CIS
Optical Resolution
2400 x 4800 dpi
Grey Scale Depth
8 bit
Colour Depth
24 bit
Colour Depth (Internal)
48 bit
Document & Media Handling
Max Original Size
Original Type
Sheets
Max Media Size
Legal
Min Media Weight
64 g/m²
Max Media Weight
300 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm)
Borderless Photo Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
125 sheets
Input tray - 125 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 300 g/m² , Paper cassette - 20 sheets - 130 x 180 mm - 300 g/m² , CD/DVD/BD tray
Speed Details
Printing: up to 15 ipm - B/W , Printing: up to 10 ipm - colour , Printing: 21 sec ( 10 x 15 cm (4"x6") ) - photo , Copying: up to 7.7 ipm - colour
1 x USB 2.0 , 1 x LAN
Security Protocols & Features
WEP, WPA-PSK, WPA2-PSK
Operating System Support
MS Windows 7, MS Windows Vista SP1, MS Windows XP SP3, MS Windows 7 64-bit Edition, MS Windows Vista SP2, MS Windows Vista SP2 64-bit Edition, Apple Mac OS X 10.5.8 - 10.8
Software Included
Drivers & Utilities, Canon Easy-WebPrint EX, Auto Photo Fix II, Canon Full HD Movie Print, Canon Creative Park Premium, Canon My Image Garden
19 Watt
Power Consumption Standby
0.9 Watt
Power Consumption Sleep
0.3 Watt
Direct Printing Specifications
PictBridge
First Copy Out Time Colour
14 sec
Consumables Included
1 x ink tank ( pigmented black ) - up to 300 pages - Canon PGI-550PGBK , 1 x ink tank ( black ) - up to 1105 pages - Canon CLI-551BK , 1 x ink tank ( cyan ) - up to 304 pages - Canon CLI-551C , 1 x ink tank ( magenta ) - up to 298 pages - Canon CLI-551M , 1 x ink tank ( yellow ) - up to 330 pages - Canon CLI-551Y , 1 x ink tank ( grey ) - up to 780 pages - Canon CLI-551GY
46.6 cm
36.9 cm
14.8 cm
8.4 kg
Sound Emission
51.6 dB (operating)
5 °C
35 °C
10 - 90% (non-condensing)
Accessories
£12.21
Canon CLI-551 XL Black Ink Cartridge
Quicklinx: 8DX7 | In Stock
£11.20
Canon CLI-551 XL Cyan Ink Cartridge
Quicklinx: 8DX8 | In Stock
£11.12
Canon CLI-551 XL Magenta Ink Cartridge
Quicklinx: 8DX9 | In Stock
£11.20
Canon CLI-551 XL Yellow Ink Cartridge
Quicklinx: 8DXB | In Stock
£11.20
Canon CLI-551 XL Grey High Yield Ink Tank
Quicklinx: 8F08 | In Stock
£11.65
Scroll to top
