BT.com
Wishlist
Canon PIXMA MG5450 - Multifunction ( printer / copier / scanner ) - colour - ink-jet - wifi
Delivery
Standard Due date unavailable
High performance Photo All-in-One with Wi-Fi, Internet printing and individual inks.
High performance Photo All-in-One with 5 individual inks and stylish low-profile design. Easy to operate, with intuitive interface and colour display, it offers mobile and Internet printing.
High performance 5-ink Photo All-in-One
Internet printing with PIXMA Cloud Link
Low profile, stylish design
Mobile printing & Apple AirPrint
Quality printing, fast
My Image Garden software
Direct Disc Print & Auto Duplex
Print more with optional XL inks
High performance
With Wi-Fi connectivity and Cloud Link, this Photo All-in-One provides convenient access and easy sharing around the home. You can print from the Internet, from virtually anywhere, as well as from mobile devices. The 5-ink system makes it ideal for high quality printing of documents and photos, copying and scanning. It has a class-leading FINE print head with 1pl, delivering 9600dpi print resolution and fast A4 ISO ESAT print speed of 15ipm mono/10ipm colour.
Internet printing
Print direct from the Internet, with PIXMA Cloud Link. Use the printer screen to choose and print photos from your online albums at CANON iMAGE GATEWAY and Google's Picasa. Access on demand calendars, stationery and other templates from the PIXMA Cloud. Print emails, photo and PDF attachments, and Google Docs from your Gmail account, from virtually anywhere, using Google Cloud Print.
Smartphone and Tablet ready
Canon's Easy-PhotoPrint app lets you wirelessly print from and even scan to your smartphone and tablet. Support for Apple AirPrint means you can also print photos, emails, web pages and other documents from your iPhone, iPad and iPod touch.
Stylish design
With its compact, low profile styling, this All-in-One looks great and requires minimum space. The Snap Edge design makes replacing ink quick and easy, while two paper cassettes can hold plain and photo paper at the same time.
Creative software
My Image Garden software realises the full potential of your PIXMA, with easy management of photo printing, scanning and access to online services. Face recognition and superb photo organising capabilities enable you to search all the photos stored on your PC and combine them in creative ways. You can personalise your discs and make them easier to organise by printing directly on Blu-ray disc, CD and DVD. With Print Your Days you can arrange and print your photos direct from Facebook.
Save with PIXMA
Cut paper usage and create professional looking documents with automatic double-sided printing. Save energy with Auto Power On/Off, which automatically turns the printer off after a selected time, and conveniently back on when you start printing. Save money with individual ink tanks as you only change the colour that has run out. Cost effective XL inks print up to 2.2 times more pages than a standard one, so need replacing less frequently - ideal if you print a lot.
Canon PIXMA MG5450 - multifunction printer ( colour )
Printer / copier / scanner
Copier Type
Digital
Printing Technology
Ink-jet ( colour )
Inkjet Technology
Canon FINE (Full-lithography inkjet Nozzle Engineering) - 5-ink
Max Copying Speed
7.7 ppm (colour)
Max Printing Speed
Up to 15 ipm (mono) / up to 10 ipm (colour)
Max Printing Resolution
9600 x 2400 dpi (colour)
Scanning
2400 x 4800 dpi
Original Size
A4 (210 x 297 mm), Letter A (216 x 279 mm) (max)
Original Type
Sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, photo paper, printable CD/DVD/BD disk
Standard Media Capacity
125 sheets
Automatic Duplexing
Yes (printing)
PC Connection Availability
PC Connection
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
Print from memory card, scan to folder, scan to network, Auto Photo Fix II, PIXMA Cloud Link, Google Cloud Print ready, red-eye correction
AC 110/230 V ( 50/60Hz )
45.5 cm x 36.9 cm x 14.8 cm
8 kg
Copier Type
Digital
Printing Technology
Ink-jet - colour - photo
Display Features
Intelligent Touch System
PC Connection
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Supported Flash Memory
SD Memory Card, MultiMediaCard, Memory Stick Duo, MultiMediaCardplus, Memory Stick PRO Duo, SDHC Memory Card
Copying
Max Copying Speed
7.7 ppm (colour)
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
2 on 1, BorderFree, 4 on 1, fit to page, Frame Erase Copy, collation copy
Printing
Inkjet Technology
Max Printing Speed
Ink Cartridge Configuration
5 individual ink tanks
5-ink
Minimum Ink Droplet Size
1 pl
Ink Type
Canon ChromaLife100+
Automatic Duplexing
Scanning
Scan Element
CIS
Optical Resolution
2400 x 4800 dpi
Grey Scale Depth
8 bit
Colour Depth
24 bit
Colour Depth (Internal)
48 bit
Document & Media Handling
Max Original Size
Original Type
Sheets
Max Media Size
Legal
Min Media Weight
64 g/m²
Max Media Weight
300 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm)
Borderless Photo Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
125 sheets
Input tray - 125 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 300 g/m² , Paper cassette - 20 sheets - 130 x 180 mm - 300 g/m² , CD/DVD/BD tray
Speed Details
Printing: up to 15 ipm - B/W , Printing: up to 10 ipm - colour , Printing: 21 sec ( 10 x 15 cm (4"x6") ) - photo , Copying: up to 7.7 ipm - colour
1 x USB 2.0
Security Protocols & Features
WEP, WPA-PSK, WPA2-PSK
Operating System Support
MS Windows 7, MS Windows Vista SP1, MS Windows XP SP3, MS Windows 7 64-bit Edition, MS Windows Vista SP2, MS Windows Vista SP2 64-bit Edition, Apple Mac OS X 10.5.8 - 10.8
Software Included
Drivers & Utilities, Canon Easy-WebPrint EX, Auto Photo Fix II, Canon Full HD Movie Print, Canon Creative Park Premium, Canon My Image Garden
16 Watt
Power Consumption Standby
0.9 Watt
Power Consumption Sleep
0.3 Watt
Direct Printing Specifications
PictBridge
First Copy Out Time Colour
14 sec
Consumables Included
1 x ink tank ( pigmented black ) - up to 300 pages - Canon PGI-550PGBK , 1 x ink tank ( black ) - up to 1795 pages - Canon CLI-551BK , 1 x ink tank ( cyan ) - up to 332 pages - Canon CLI-551C , 1 x ink tank ( magenta ) - up to 319 pages - Canon CLI-551M , 1 x ink tank ( yellow ) - up to 344 pages - Canon CLI-551Y
45.5 cm
36.9 cm
14.8 cm
8 kg
Sound Emission
44.4 dB (operating)
5 °C
35 °C
10 - 90% (non-condensing)
Accessories
£12.21
Canon CLI-551 XL Black Ink Cartridge
Quicklinx: 8DX7 | In Stock
£11.20
Canon CLI-551 XL Cyan Ink Cartridge
Quicklinx: 8DX8 | In Stock
£11.25
Canon CLI-551 XL Magenta Ink Cartridge
Quicklinx: 8DX9 | In Stock
£11.20
Canon CLI-551 XL Yellow Ink Cartridge
Quicklinx: 8DXB | In Stock
£11.20
£31.03
Canon CLI-551 Black Ink Tank
Quicklinx: 8TD0 | In Stock
£9.01
Canon CLI-551 Cyan Ink Tank
Quicklinx: 8TD3 | In Stock
£8.74
Canon CLI-551 Yellow Ink Tank
Quicklinx: 8TD4 | In Stock
£8.88
Canon CLI-551 Magenta Ink Tank
Quicklinx: 8TD5 | In Stock
£8.88
Scroll to top
