BT.com
Wishlist
Canon MF6180DW A4 Mono Laser Multifunction Printer
Delivery
Standard Due date unavailable
It is designed for cost-effective black and white printing in connected multi-user businesses.
Make black and white printing easy and convenient with this Wi-Fi-enabled, cloud-ready 4-in-1 printer. Fast, energy-efficient operation and 33 ppm printing saves you time and money.
Canon i-SENSYS MF6180dw - multifunction printer (B/W)
Fax / copier / printer / scanner
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
50000 impressions
Max Copying Speed
Up to 33 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 33 ppm
Max Printing Resolution
Up to 1200 x 600 dpi
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 400 x 400 dpi
Scanning
600 x 600 dpi
Original Size
128 x 139.7 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels, recycled paper, bond paper, heavy-weight paper
Standard Media Capacity
300 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
PC Connection Availability
PC Connection
USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to network, Google Cloud Print ready
AC 230 V (50/60Hz)
39 cm x 47.3 cm x 43.1 cm
19.1 kg
Environmental Standards
ENERGY STAR Qualified
Fax Type
Plain paper
Printing Technology
Laser - monochrome
50000 impressions
Display
5 lines
PC Connection
AirPrint Enabled
Standard Memory
256 MB
Copying
Max Copying Speed
Up to 33 ppm
Up to 600 x 600 dpi
Grayscale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Exposure Modes
Text, photo, text and photo
Automatic Duplexing
Copying Features
Toner Save, 2 on 1, 4 on 1, ID Card Copy, Frame Erase Copy, collation copy
Printing
Max Printing Speed
Up to 33 ppm
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3, UFRII LT
Image Enhancement Technology
Automatic Image Refinement
Automatic Duplexing
First Print Out Time B/W
6 sec
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Interpolated Resolution
9600 x 9600 dpi
Colour Depth
24-bit
Colour Depth (Internal)
24-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Max Battery Backup Time
1 hour(s)
Total Memory Capacity
Up to 512 pages
PC Faxing
Fax Machine Features
Error Correction Mode (ECM)
One-Touch Dialing
19 station(s)
Speed Dialing
200 station(s)
Broadcast Transmission
210 stations
Fax forwarding, Distinctive Ring Pattern Detection (DRPD), automatic redialing, remote reception, Dual Access, Double Sided Faxing, fax activity reports
Document & Media Handling
Min Original Size
128 x 139.7 mm
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Statement (139.7 x 215.9 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
300 sheets
50 sheets
150 sheets
ADF - 50 sheets size: 128 x 139.7 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 105 g/m² , Paper cassette - 250 sheets size: B5 (176 x 250 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 128 g/m² , Bypass tray - 50 sheets size: 76 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Output tray - 150 sheets
Speed Details
Copying: up to 33 ppm (A4) - B/W , Printing: up to 33 ppm (A4) - B/W
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
Security Protocols & Features
Secure Print, IPsec, 802.1x
Operating System Support
MS Windows XP, Linux, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.5.8 or later, MS Windows Server 2012, Windows 8, Android, iOS
Software Included
Drivers & Utilities, Presto! PageManager, Canon MF Toolbox
AC 230 V (50/60Hz)
1200 Watt
Power Consumption Standby
9 Watt
Power Consumption Sleep
2.2 Watt
Warm-Up Time
11 sec
First Copy Out Time B/W
8 sec
Consumables Included
1 x Cartridge (black) - Canon 719
ENERGY STAR Certified
39 cm
47.3 cm
43.1 cm
19.1 kg
Sound Emission
53 dBA (operating)
10 °C
30 °C
20 - 80% (non-condensing)
Scroll to top
