BT.com
Wishlist
Canon LiDE 110
Delivery
Standard Due date unavailable
Are you looking for a dedicated scanning solution with great quality, versatility and a compact design? Then the CanoScan LiDE110 color image scanner is sure to impress. The CanoScan LiDE110 features the quality, speed and ease of use you need with a maximum resolution of 2400 x 4800 (optical) dpi for excellent scanning quality for both photos and documents.
You'll immediately notice how easy the CanoScan LiDE110 is to use. Auto document fix automatically delivers beautiful, easy-to-view scans by advanced image analysis and area-by-area data correction while the auto scan mode feature automatically detects the original and saves its appropriate settings. Need to share information? The CanoScan LiDE110 has four EZ buttons that enable you to scan, copy, email or create a PDF faster than ever.
You'll also be able to proudly join the generation green initiative as its one USB cable for data and power provides lower power consumption.
Canon CanoScan LiDE 110 - flatbed scanner
Flatbed scanner - desktop
Interface Type
USB 2.0
Scan Element Type
Contact Image Sensor (CIS)
Light Source
RGB LED array
Max Supported Document Size
A4 (210 x 297 mm)
Input Type
Grayscale / Color Depth
16-bit (64K grey levels) / 48-bit colour
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 48-bit colour
Optical Resolution
2400 dpi x 4800 dpi
Interpolated Resolution
19200 dpi x 19200 dpi
Scan Speed
16 sec / page
Max Document Size
216 mm x 297 mm
Supported Document Type
Plain paper
Document Feeder Type
Manual
Microsoft Windows XP SP2, Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.6, Microsoft Windows Vista SP2, Apple MacOS X 10.5, Microsoft Windows Vista SP1, Apple MacOS X 10.4.11, Microsoft Windows XP SP3
Microsoft Certification
Compatible with Windows 7
25 cm x 37 cm x 4 cm
1.6 kg
Interface Type
USB 2.0
A4 (210 x 297 mm)
Scanner
Input Type
Grayscale Depth
Grayscale Depth (External)
Colour Depth
48-bit colour
Colour Depth (External)
48-bit colour
Optical Resolution
2400 dpi x 4800 dpi
Scan Element Type
Bulb / Light Source Type
RGB LED array
Scan Speed
16 sec / page
Control Panel Buttons Functions
Copy, email, AutoScan, Scan-to-PDF
Scanner Speed Details
16 sec/scan - colour - A4 - 300 dpi , 3.7 ms/line - colour - 300 dpi , 16.7 ms/line - colour - 2400 dpi , 3.7 ms/line - greyscale - 300 dpi , 5.6 ms/line - greyscale - 2400 dpi , 3.7 ms/line - black & white - 300 dpi , 5.6 ms/line - black & white - 2400 dpi
Scanner Features
Powered by USB port
Media Handling
Max Document Size
216 mm x 297 mm
Plain paper
Manual
USB 2.0
Power Consumption Operational (Standby)
2.5 Watt (1.4 Watt)
Software Included
ScanGear, Canon Solution Menu, MP Navigator EX
Additional Requirements
CD-ROM, XGA monitor
System Requirements Details
Windows 7 - 1 GHz - RAM 1 GB , Windows 7 64-bit Edition - 1 GHz - RAM 2 GB , Windows Vista - 1 GHz - RAM 512 MB , Windows XP - 300 MHz - RAM 128 MB , MacOS X 10.4.11 - PowerPC G3 RAM 256 MB , MacOS X 10.5 - PowerPC G4 RAM 512 MB , MacOS X 10.6 - Intel x86 RAM 1 GB
25 cm
37 cm
4 cm
1.6 kg
5 °C
35 °C
10 - 90%
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Good value for money.
Reviewed by Bergamot Eng. on 23/09/2013
As previous Canon Lide scanner it does the job very well for its super sweet price.
Scroll to top
