BT.com
Wishlist
Canon IXUS 500 HS Digital Camera - Silver
Delivery
Standard Due date unavailable
The IXUS 500 HS brings a big 12x zoom to a compact, stunning metal body - getting you closer, in style. With HS System, Intelligent IS and Smart Auto, shooting great images is easy, even in low light. Amazing by design. Tiny, 12x zoom IXUS.
12x zoom in tiny and stunning metal body
With a tiny metal body in an amazing finish the IXUS 500 HS packs a powerful 12x optical zoom extending to 21x with ZoomPlus. The huge zoom offers a wide range of shooting options and lets you get right up close to distant objects whether shooting stills or movies.
HS System: 10.1 MP CMOS
The HS System excels in low light so you can capture the real atmosphere of the scene without flash or tripod. Advanced DIGIC 5 processing and a high sensitivity 10.1 Megapixel CMOS sensor give excellent image quality in all situations.
Intelligent IS
Intelligent IS automatically adjusts the optical Image Stabilizer to the scene from 7 modes - counteracting movement to prevent blur and delivering sharp and detailed photos and movies at full zoom and in low light.
7.5 cm (3.0") PureColor II G LCD
A large, high quality 460k dot LCD screen with excellent visibility allows easy framing and reviewing of images from any angle plus effortless menu navigation. A tempered glass outer layer gives excellent durability.
Full HD movies
Record superb Full HD (1080p) movies at 24fps with stereo sound and optical zoom. Intelligent IS keeps footage steady while filming, even at full zoom. An HDMI connection ensures high quality playback on an HDTV.
Smart Auto (58 scenes)
Effortlessly shoot great photos or movies with Smart Auto, which detects the scene and selects perfect settings from 58 variables. It also works with faces registered with Face ID and adapts shooting settings to the person's age - for example turning off flash and sounds when a sleeping baby is detected or engaging continuous auto-focus when children over 2 years old are detected.
Face ID
Face ID lets you register up to 12 faces of family and friends, so they are automatically the focusing priority in every shot, and tags images with their names so they are easy to find in playback.
High-speed shooting
Never miss a moment. Capture fast-paced action with High-speed Burst or slow down fast movement with Super Slow Motion Movie. Handheld Night Scene combines a sequence of high-speed shots into one file to capture nightscapes without a tripod.
Movie Digest (720p)
Movie Digest records up to 4-seconds of action before each still shot, joining the day's clips into a bonus HD (720p) movie.
Canon IXUS 500 HS - digital camera
Digital camera - 1080p - compact
Image Processor
DIGIC 5
Sensor Resolution
10.1 Megapixel
Max Video Resolution
1920 x 1080
Lens System
Zoom lens - 12 x zoom - 4 - 48 mm - f/3.4-5.6
Focus Adjustment
Automatic
Min Focus Distance
1 cm
Digital Zoom
4 x
Image Stabiliser
Optical
Camera Flash
Built-in flash
Display
LCD display - 3"
Supported Battery
1 x Canon NB-9L Li-ion rechargeable battery ( included )
Interfaces Provided
HDMI, USB 2.0
Microsoft Certification
Compatible with Windows 7
Silver
8.7 cm x 1.9 cm x 5.4 cm
155 g
Scroll to top
