BT.com
Wishlist
Canon i-SENSYS MF418x A4 Mono Laser Multifunction Printer
Delivery
Standard Due date unavailable
An ideal addition to your fleet of networked printers, the smart, simple and compact MF418x black and white Multifunctional printer offers laser-quality print, copy and scanning plus full support for flexible working.
Benefits
* Black and white A4 laser Multifunctional printer with WiFi that’s tailor-made for small workgroups
* Fast, professional-quality printing at up to 33ppm
* Easy operation using the intuitive colour touch screen
* Automatic duplex printing reduces waste and overheads
* Quick First-Print saves time and keeps your teams productive
* Secure PIN printing
* AirPrint, Mopria and the Canon PRINT Business app for printing from smartphones and tablets
* Works easily with popular cloud storage services * Easy integration with device and output management capabilities
* Simple to maintain with convenient All-In-One Cartridges
Work smarter in the office-
Small workgroups can gain a welcome productivity boost from the MF418x A4 laser Multifunctional printer. Offering professional-quality printing speeds of up to 33ppm, the MF418x is versatile enough to handle all your document needs despite its impressively compact size. An intuitive 3.5" colour touch screen, 550-page paper capacity and Quick First-Print from start-up all help your teams to work more efficiently and without interruption. The MF418x also offers a convenient privacy feature a convenient privacy feature: the Secure Print function protects your documents with a PIN code, even when you’re printing from a mobile device.
Flexible working-
Thanks to the MF418x’s extensive support for Apple AirPrint (iOS) and Mopria (Android), your workgroup can print from any enabled device. They can also access a wide range of advanced features with the Canon PRINT Business app and can connect the device to a Google Cloud Print account in seconds.
Enhanced document sharing-
The cloud-ready MF418x can help your business to become more agile. Using the MF Scan Utility (for PCs/laptops) and the Canon PRINT Business app (for mobile devices), everyone can connect seamlessly between the MF418x and popular cloud storage services like Evernote® and DropBox to capture, digitise and share documents on the go – or simply to scan and email in a single operation.
Smart networking capabilities-
With a host of flexible networking capabilities, the MF418x makes a perfect addition to your network. WiFi and Ethernet connectivity, alongside support for PCL5e/6 and Adobe PostScript printer languages, enable hassle-free integration into managed network environments. With Canon’s e-Maintenance remote service management and support for Canon’s uniFLOW output management system make the MF418x equally well-suited to managed network environments.
Simple and sustainable ownership-
Consistent reliability and renewed quality are ensured every time you change your toner thanks to Canon’s All-In-One Cartridge design that replaces all key components at once with every toner change. And with low energy consumption in Sleep and Standby modes, automatic duplex printing, and a smart power-saving Auto Off feature, the MF418x makes a sustainable, cost-conscious choice.
What's in the box
  • Canon i-SENSYS MF418x
  • Cartridge - black - Canon 719
Canon i-SENSYS MF418x - multifunction printer (B/W)
Multifunction printer
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
50000 pages
Recommended Monthly Volume
1000 - 5000 pages
Max Copying Speed
Up to 33 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 33 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Scanning
600 x 600 dpi
Display
3.5"
Original Size
128 x 139.7 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, heavy-weight paper, postcards
Standard Media Capacity
550 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Save to USB flash drive, scan to e-mail, scan to Cloud, scan to FTP, scan to PC
AC 230 V (50/60Hz)
45 cm x 47.2 cm x 46.5 cm
21.2 kg
Printing Technology
Laser - monochrome
50000 pages
1000 - 5000 pages
Display Diagonal Size
3.5"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
1 GB
Copying
Max Copying Speed
Up to 33 ppm
Up to 600 x 600 dpi
Grayscale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Exposure Modes
Text, photo, text and photo
Automatic Duplexing
Copying Features
Toner Save, 2 on 1, 4 on 1, ID Card Copy, Frame Erase Copy, collation copy
Printing
Max Printing Speed
Up to 33 ppm
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3, PDF, TIFF, UFRII
Automatic Duplexing
First Print Out Time B/W
6.3 sec
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Interpolated Resolution
9600 x 9600 dpi
Colour Depth
24-bit
Colour Depth (Internal)
24-bit
Document & Media Handling
Min Original Size
128 x 139.7 mm
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Oficio (216 x 343 mm), Foolscap (216 x 343 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
550 sheets
50 sheets
150 sheets
ADF - 50 sheets size: 128 x 139.7 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 105 g/m² , Paper cassette - 500 sheets size: 105 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 128 g/m² , Bypass tray - 50 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 33 ppm (A4) - B/W , Printing: up to 16.8 ipm (A4) - B/W duplex , Copying: up to 33 ppm (A4) - B/W , Copying: up to 16.8 ipm (A4) - B/W duplex , Scanning: up to 33 ppm - B/W , Scanning: up to 13 ipm - B/W duplex , Scanning: up to 11 ipm - colour , Scanning: up to 7 ipm - colour duplex
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
Security Protocols & Features
Secure Print, WEP, WPA-PSK, IPsec, 802.1x, WPA2-PSK, TKIP, AES, IP filtering, ARP, MAC address filtering
Operating System Support
Linux, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, MS Windows Server 2003 R2, MS Windows Server 2012, Windows 8, Android, iOS, Windows 8.1, Apple Mac OS X 10.6 or later, MS Windows Server 2012 R2, Windows 10
Software Included
Drivers & Utilities, Presto! PageManager, iW Management Console, Canon PRINT Business
AC 230 V (50/60Hz)
1160 Watt
Power Consumption Standby
8.7 Watt
Power Consumption Sleep
1.4 Watt
First Copy Out Time B/W
10 sec
Consumables Included
1 x Cartridge (black) - up to 2100 pages - Canon 719
45 cm
47.2 cm
46.5 cm
21.2 kg
Sound Emission
53 dB (operating)
10 °C
30 °C
20 - 80% (non-condensing)
Scroll to top
