BT.com
Wishlist
Canon i-SENSYS MF212w Mono Multifunction Laser Printer
Delivery
Standard Due date unavailable
Seamlessly share print, copy and scan functions with this Wi-Fi, network and mobile ready mono laser 3-in-1. Quick, easy-to-use and energy efficient, it features a tilting control panel and one-touch solution keys.
Canon i-SENSYS MF212W - multifunction printer (B/W)
Multifunction printer
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
8000 pages
Max Copying Speed
Up to 23 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 23 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Scanning
600 x 600 dpi
Original Size
216 mm width (max)
Original Type
Sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, labels, recycled paper, heavy-weight paper
Standard Media Capacity
250 sheets
Output Trays Capacity
100 sheets
Connection Availability
USB 2.0, LAN, Wi-Fi(n)
AirPrint Enabled
AC 230 V (50/60Hz)
39 cm x 44.1 cm x 31.2 cm
10.2 kg
Printing Technology
Laser - monochrome
8000 pages
Display
5 lines
AirPrint Enabled
Standard Memory
256 MB
Copying
Max Copying Speed
Up to 23 ppm
Up to 600 x 600 dpi
Grayscale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Exposure Modes
Text, photo, text and photo
Copying Features
Toner Save, 2 on 1, 4 on 1, ID Card Copy
Printing
Max Printing Speed
Up to 23 ppm
Printer Drivers / Emulations
UFRII LT
Image Enhancement Technology
Automatic Image Refinement
First Print Out Time B/W
6 sec
Scanning
Optical Resolution
600 x 600 dpi
Interpolated Resolution
9600 x 9600 dpi
Colour Depth
24-bit
Document & Media Handling
Max Original Size
216 mm width
Original Type
Sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Oficio (216 x 343 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
250 sheets
100 sheets
Input tray - 250 sheets size: 76.2 x 210 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Bypass tray size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Output tray - 100 sheets
Speed Details
Printing: up to 23 ppm (A4) - B/W , Copying: up to 23 ppm (A4) - B/W
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Operating System Support
MS Windows XP, Linux, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.5.8 or later, MS Windows Server 2012, Windows 8, Android, iOS, Windows 8.1, MS Windows Server 2012 R2
Software Included
Drivers & Utilities, Presto! PageManager, Canon MF Toolbox
AC 230 V (50/60Hz)
1270 Watt
Power Consumption Standby
3.2 Watt
Power Consumption Sleep
1.6 Watt
First Copy Out Time B/W
9 sec
Consumables Included
1 x Cartridge (black) - up to 1700 pages
39 cm
44.1 cm
31.2 cm
10.2 kg
Sound Emission
43 dB (idle) / 50 dB (operating)
10 °C
30 °C
20 - 80% (non-condensing)
Accessories
£3.74
£13.46
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.26
£52.42
Scroll to top
