Click to visit BT.com
BT.com
Wishlist
Canon EOS 7D & Canon EF-S 15-85mm IS USM lens
EOS 7D Digital SLR Camera
Quicklinx: 6LHCWS00
Mfr#: 3814B028AA
Essential accessories
With a host of features designed to enhance every facet of the photographic process, from still images to video, the EOS 7D represents a whole new class of camera.
Made to be the tool of choice for serious photographers and semi-professionals, the EOS 7D features an 18.0 megapixels APS-C size CMOS sensor and dual DIGIC 4 image processors, capturing tremendous images at up to ISO 12800 and speeds of up to 8 fps. The EOS 7D has a cross-type 19-point AF system with improved AI Servo AF subject tracking and user-selectable AF area selection modes for sharp focus no matter the situation. The EOS 7D's Intelligent Viewfinder provides 100% coverage and displays user-selected AF modes as well as a spot metering circle and on demand grid lines. iFCL metering with 63-zone dual-layer metering system uses both focus and color information to provide accurate exposure even in difficult lighting. The EOS 7D also captures Full HD video at 30p, 24p and 25p with an array of manual controls, including manual exposure during movie shooting and ISO speed selection. The EOS 7D features a magnesium alloy body that is dust- and weather-resistant and shutter durability of up to 150,000 cycles.
Canon EOS 7D - digital camera EF-S 15-85mm IS USM lens
Digital camera - 1080p - SLR with Live View mode, movie recording
Lens Included
Memory Card Slot
CompactFlash Card
Image Processor
Dual DIGIC 4
Sensor Resolution
18.0 Megapixel
Lens System
5.6 x zoom lens - 15 - 85 mm - f/3.5-5.6 Canon EF-S
Focus Adjustment
Automatic, manual
Min Focus Distance
35 cm
Image Stabiliser
Optical
Camera Flash
Pop-up flash
Viewfinder
Optical - fixed eye-level pentaprism
Display
LCD display - 3"
Supported Battery
1 x Li-ion rechargeable battery ( included )
Interfaces Provided
Composite video/audio, HDMI, USB 2.0
Microsoft Certification
Compatible with Windows 7
14.8 cm x 7.4 cm x 11.1 cm
0.82 kg
Lens Included
Sensor Resolution
18.0 Megapixel
Optical Sensor Type
CMOS
Total Pixels
19,000,000 pixels
Effective Sensor Resolution
18,000,000 pixels
Optical Sensor Size
14.9 x 22.3mm
Field of View Crop Factor
1.6
ISO (Max)
12800
Sensor Dust Reduction
Sensor Features
EOS Integrated Cleaning System, Anti-Dust coating
Optical Zoom
5.6 x
Image Processor
Dual DIGIC 4
Image Stabiliser
Optical
Face Detection
Print Standard
Direct print, DPOF support, Exif Print support, PictBridge support
Auto Focus
TTL contrast and phase detection
Auto Focus Points (Zones) Qty
19
Digital Video Format
H.264
Image Recording Format
JPEG, RAW, RAW + JPEG
Interfaces Provided
Exposure & White Balance
Light Sensitivity
ISO auto (100-3200), ISO 12800, ISO 100-6400
Exposure Metering
Evaluative, spot (2.3%), centre-weighted, partial (9.4%)
Exposure Metering Zones
63
Exposure Modes
Programme, automatic, manual, aperture-priority, shutter-priority, E-TTL II program flash
Special Effects
Neutral, Faithful, monochrome, landscape, portrait
White Balance
Custom, automatic, presets
White Balance Presets
Fluorescent, cloudy, tungsten light, Flash, daylight, shade
Max Shutter Speed
1/8000 sec
Min Shutter Speed
30 sec
Exposure Compensation
±5 EV range, in 1/2 or 1/3 EV steps
Auto Exposure Bracketing
3 steps in 1/2 or 1/3 EV steps
White Balance Bracketing
X-sync Speed
1/250sec
Exposure Range
EV 1-20 ( ISO 100 )
Lens System
Focal Length Equivalent to 35mm Camera
24 - 136mm
Focus Adjustment
Automatic, manual
Min Focus Distance
35 cm
Max View Angle
84.5 degree(s)
Zoom Adjustment
Manual
Lens Construction
12 groups / 17 elements
Filter Size
72 mm
Lens Mounting Type
Canon EF
UD glass, Ultrasonic Motor (USM), aspherical lens
Camera Flash
Camera Flash
Pop-up flash
Guide Number (m / ISO 100)
12
Flash Modes
Rear curtain sync, auto mode, flash OFF mode
AF illuminator, flash +/- compensation, wireless off-camera control
Additional Features
Continuous Shooting Speed
8 frames per second, 3 frames per second
Self Timer Delay
10 sec, 2sec
Flash Terminal
Hot shoe, PC terminal
Additional Features
RGB primary colour filter, auto power save, digital noise reduction, date/time stamp, depth-of-field preview button, digital image rotation, camera orientation detection, histogram display, AE lock, AF lock, FE lock, LCD live view mode, highlight point display, in-camera film editing, Light Source detection AF, Dust Delete Data system, Auto Lighting Optimizer, automatic display brightness adjustment, peripheral illumination correction
Viewfinder
Viewfinder Type
Optical Viewfinder Field Coverage
100%
Optical Viewfinder Magnification
1.0x
Optical Viewfinder Dioptric Correction Range
-3 to +1
Viewfinder Frames
Autofocus frame
Display
3" LCD display
Resolution
920,000 pixels
Display Form Factor
Built-in
Display Features
Display brightness control
Microphone
Microphone Operation Mode
Mono
Connector Type
1 x composite video/audio output , 1 x USB , 1 x HDMI output , 1 x remote control , 1 x microphone
Software
Software
Drivers & Utilities, Canon PhotoStitch, Canon ZoomBrowser EX, Canon ImageBrowser, Canon Digital Photo Professional
Eyepiece cover, battery charger, dust cap, body cap, lens cap, neck strap, USB cable, eyecup, audio / video cable
Body Material
Magnesium alloy
Protection
Weatherproof, dust resistant
Battery Type
Canon LP-E6
Details
Memory / Storage
Memory Card Slot
CompactFlash Card
Supported Memory Cards
CompactFlash, Microdrive
Image Storage
JPEG 5184 x 3456 , JPEG 3456 x 2304 , JPEG 2592 x 1728 , RAW 5184 x 3456 , RAW 3888 x 2592 , RAW 2592 x 1728
Video Capture
1920 x 1080 - 30 fps , 1920 x 1080 - 25 fps , 1920 x 1080 - 24 fps , 1280 x 720 - 60 fps , 1280 x 720 - 50 fps , 640 x 480 - 60 fps , 640 x 480 - 50 fps
14.8 cm
7.4 cm
11.1 cm
0.82 kg
6LHC Canon TC 80N3 - camera remote control In Stock £137.56
6LHC Canon EF-S 17-55mm f/2.8 IS USM Lens In Stock £626.59
6LHC Canon EF-S 10- 22 mm f/3.5-4.5 USM Wide Angle Zoom Lens In Stock £426.22
6LHC Canon HTC 100 - Video / audio cable - HDMI - 19 pin HDMI (M) - 19 pin mini HDMI (M) In Stock £49.95
6LHC Canon RS 80N3 - Remote control - cable In Stock £45.32
6LHC Canon EF 50 mm f/1.4 USM Standard and Medium Telephoto Lens In Stock £271.70
6LHC Canon EF 50 mm - f/1.2 L USM Lens In Stock £1,165.74
6LHC Canon EF 100 mm - f/2.0 USM Telephoto lens In Stock £366.82
6LHC Canon EF - Telephoto zoom lens - 70 mm - 200 mm - f/2.8 L USM - Canon EF In Stock £1,068.94
6LHC Canon EF 16-35mm f/2.8L II USM Lens In Stock £1,259.58
