Click to visit BT.com
BT.com
Wishlist
Canon EOS 700D - DSLR - with EF-S 18-55mm IS STM Lens
Quicklinx: 8LMQWS00
Mfr#: 8596B027AA
Type: SLR
Resolution: 18Megapixel
Optical Zoom: 3
Hurry, only 3 left in stock!
£494.31
Essential accessories
Let your creativity grow
Step into DSLR photography and let your creativity grow. Produce superb photos and video with an 18-megapixel sensor and enjoy shooting with an easy to use Vari-angle Clear View LCD II Touch screen.
Create high-quality low-noise images that are packed with detail
Shoot 18-megapixel photos and Full-HD video from the same camera
Movie Servo AF keeps moving subjects in focus when shooting video
Explore different shooting angles with a Vari-Angle Clear View LCD II Touch Screen
Get shooting quickly and easily with Scene Intelligent Auto
Superb image quality
Capture every detail with an 18-megapixel Hybrid CMOS AF sensor. The EOS 700D produces low-noise images that can be printed at large sizes or cropped for alternative compositions.
Produce Full HD movie projects
Shoot video at 1080p resolution, enjoying the right level of automatic or manual control for you. Hybrid AF technology enables continuous focusing when shooting video, and the EOS 700D supports near-silent Movie Servo AF with compatible STM lenses. Record stereo sound with a built-in or external microphone.
Keep up with fast moving action
Track moving subjects even if they move across the scene with an autofocus system comprising 9 cross-type AF points. Continuous shooting at 5 fps for bursts of up to 22 shots means you'll never miss that decisive moment.
Explore new angles
Compose photos and movies from new and interesting angles using the EOS 700D's Vari-angle 7.7cm (3.0") 3:2 ratio Clear View LCD II Touch screen. Shoot over the top of crowds, or go for a dramatic ground-level viewpoint.
Touch-screen control
The EOS 700D is easy to use from the moment you first pick it up. Shoot and focus with a single tap of the camera's touch screen, and use pinch and swipe gestures to navigate when reviewing images.
Shoot great pictures easily. Canon's Scene Intelligent Auto mode analyses the scene and selects the most appropriate cameras settings automatically.
Low-light performance
Take great pictures even in low light, shooting without flash to capture the true ambience of an occasion. The EOS 700D features an ISO sensitivity range of ISO 100-12800 (extendable to ISO 25600).
Great results in difficult conditions
HDR Backlight Control mode captures three different exposures and combines them into one, retaining shadow and highlight detail. The EOS 700D's Hand Held Night Scene mode captures multiple images at fast shutter speeds and blends them together for a blur-free result.
Explore with the EOS System
Take your photography further with an extensive range of lenses, accessories and flashes that make up the EOS System.
Canon EOS 700D - digital camera EF-S 18-55mm IS STM lens
Digital camera - 1080p - SLR with Live View mode, movie recording
Lens Included
Memory Card Slot
SD card
Image Processor
DIGIC 5
Sensor Resolution
18.0 Megapixel
Max Video Resolution
1920 x 1080
Lens System
3 x zoom lens - 18 - 55 mm - f/3.5-5.6 IS STM Canon EF-S
Focus Adjustment
Automatic, manual
Min Focus Distance
25 cm
Image Stabiliser
Optical
Camera Flash
Pop-up flash
Viewfinder
Optical - fixed eye-level pentamirror
Display
LCD display - 3"
Supported Battery
1 x Canon LP-E8 Li-ion rechargeable battery - 1120 mAh ( included )
Interfaces Provided
Composite video/audio, HDMI, USB 2.0
Microsoft Certification
Compatible with Windows 7
13.31 cm x 7.88 cm x 9.98 cm
580 g
Lens Included
Sensor Resolution
18.0 Megapixel
Optical Sensor Type
CMOS
Total Pixels
18,500,000 pixels
Effective Sensor Resolution
18,000,000 pixels
Optical Sensor Size
14.9 x 22.3mm
Field of View Crop Factor
1.6
ISO (Max)
25600
Sensor Dust Reduction
Sensor Features
EOS Integrated Cleaning System, Self Cleaning Sensor Unit
Optical Zoom
3 x
Image Processor
DIGIC 5
Image Stabiliser
Optical
Face Detection
Print Standard
Direct print, DPOF support, Exif Print support, PictBridge support
Auto Focus
Hybrid
Auto Focus Points (Zones) Qty
9
AE/AF Control
FlexiZone, Face-priority AF, Subject-tracking AF, Movie Servo AF
Face Detection
Automatic Face Tracking technology, Live Face detection AF mode
Digital Video Format
H.264, MOV
Image Recording Format
JPEG, RAW, RAW + JPEG
1920 x 1080
Auto Focus Features
Predictive Focus Control
Interfaces Provided
Exposure & White Balance
Light Sensitivity
ISO 25600, ISO 100-12800, ISO auto (100-6400)
Exposure Metering
Evaluative, centre-weighted, spot, partial
Exposure Metering Zones
63
Exposure Modes
Programme, bulb, automatic, manual, aperture-priority, shutter-priority
Shooting Programs
Landscape, portrait mode, close-up, night portrait, sports mode, handheld night shot, backlight correction HDR
Special Effects
Neutral, Faithful, monochrome, landscape, portrait
White Balance
Custom, automatic, presets
White Balance Presets
Cloudy, tungsten light, Flash, daylight, shade, fluorescent light (white)
Max Shutter Speed
1/4000 sec
Min Shutter Speed
30 sec
Exposure Compensation
±5 EV range, in 1/2 or 1/3 EV steps
Auto Exposure Bracketing
3 steps in 1/2 or 1/3 EV steps
White Balance Bracketing
X-sync Speed
1/200sec
Exposure Range
EV 1-20 ( ISO 100 )
Lens System
Focal Length Equivalent to 35mm Camera
29 - 88mm
Focus Adjustment
Automatic, manual
Min Focus Distance
25 cm
Max View Angle
74.3 degree(s)
Zoom Adjustment
Manual
Lens Construction
11 groups / 13 elements
Filter Size
58 mm
Lens Mounting Type
Canon EF
Internal focusing system, full-time manual focusing, aspherical lens, Stepping Motor (STM) technology
Camera Flash
Camera Flash
Pop-up flash
Guide Number (m / ISO 100)
13
Flash Modes
Fill-in mode, rear curtain sync, auto mode, flash OFF mode, red-eye reduction
AF illuminator, flash +/- compensation, wireless off-camera control
Additional Features
Continuous Shooting Speed
5 frames per second
Self Timer Delay
10 sec, 2sec
Flash Terminal
Hot shoe
Additional Features
Built-in speaker, RGB primary colour filter, auto power save, depth-of-field preview button, digital image rotation, camera orientation detection, histogram display, AE lock, AF lock, FE lock, resizing an image, GPS ready, highlight point display, Dust Delete Data system, face detection, built-in help guide, HDR image enhancement technology, Eye-Fi Card Ready, Picture Style Auto, Scene Intelligent Auto technology, Image Rating
Viewfinder
Viewfinder Type
Optical Viewfinder Field Coverage
95%
Optical Viewfinder Magnification
0.85x
Optical Viewfinder Dioptric Correction Range
-3 to +1
Viewfinder Frames
Autofocus frame
Display
3" LCD display
Resolution
1,040,000 pixels
Display Form Factor
Rotating
Touch Screen
Display Features
Display brightness control
Microphone
Microphone Operation Mode
Stereo
Connector Type
1 x USB 2.0 , 1 x composite video/audio output , 1 x HDMI output , 1 x microphone
Software
Software
Canon PhotoStitch, Canon Digital Photo Professional, Canon Picture Style Editor, Canon ImageBrowser EX, Canon EOS Utility
Eyepiece cover, battery charger, dust cap, body cap, lens cap, neck strap, USB cable, eyecup, battery cover
Body Material
Stainless steel, fibreglass-reinforced polycarbonate resin
Battery Type
Canon LP-E8
Details
Battery Life Details
Photo shooting - 440 shots ( at 23 °C (AE 50%, FE 50%) ) , Photo shooting - 400 shots ( at 0 °C (AE 50%, FE 50%) )
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card, SDHC UHS-I Memory Card, SDXC UHS-I Memory Card
Image Storage
RAW 5184 x 3456 , JPEG 5184 x 3456 , JPEG 3456 x 2304 , JPEG 1920 x 1280 , JPEG 720 x 480 , JPEG 4608 x 3456 , JPEG 3072 x 2304 , JPEG 2304 x 1728 , JPEG 1696 x 1280 , JPEG 5184 x 2912 , JPEG 3456 x 1944 , JPEG 2592 x 1456 , JPEG 1920 x 1080 , JPEG 720 x 400 , JPEG 3456 x 3456 , JPEG 2304 x 2304 , JPEG 3456 x 3456 , JPEG 2304 x 2304 , JPEG 1728 x 1728 , JPEG 1280 x 1280 , JPEG 480 x 480
Video Capture
H.264 - 1920 x 1080 - 30 fps , H.264 - 1920 x 1080 - 25 fps , H.264 - 1920 x 1080 - 24 fps , H.264 - 1280 x 720 - 60 fps , H.264 - 1280 x 720 - 50 fps , H.264 - 640 x 480 - 30 fps , H.264 - 640 x 480 - 25 fps
13.31 cm
7.88 cm
9.98 cm
580 g
0 - 85%
Canon EOS 700D - DSLR - with EF-S 18-55mm IS STM Lens Bundle deal on Canon EOS 700D - DSLR - with EF-S 18-55mm IS STM Lens
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £9.88 | in stock
£504.30
Type: SLR
Optical Zoom: 3
Brand: Canon
Price Range Inc VAT: 300 - 500
