BT.com
Wishlist
Canon EOS 60D - Digital camera - SLR - 18.0 Mpix - 7.5 x optical zoom EF-S 18-135mm IS lens
Delivery
Standard Due date unavailable
With the EOS 60D DSLR, Canon gives the photo enthusiast a powerful tool fostering creativity, with better image quality, more advanced features and automatic and in-camera technologies for ease-of-use. It features an improved APS-C sized 18.0 megapixel CMOS sensor for tremendous images, DIGIC 4 Image Processor for finer detail and excellent color reproduction, and improved ISO capabilities from 100 - 6400 (expandable to 12800) for uncompromised shooting even in the dimmest situations. The Multi-control Dial enables users to conveniently operate menus and enter settings with a simple touch. The EOS 60D also features an EOS first Vari-angle 3.0-inch Clear View LCD (1,040,000 dots) monitor for easy low- or high-angle viewing. An improved viewfinder, a number of in-camera creative options and filters, plus HDMI output for viewing images on an HDTV all make the EOS 60D invaluable for the evolving photographer. With continuously curved surfaces, user-friendliness and exuding solidity and refinement, the EOS 60D is true digital inspiration!
Canon EOS 60D - digital camera EF-S 18-135mm IS lens
Digital camera - 1080p - SLR with Live View mode, movie recording
Lens Included
Memory Card Slot
SD card
Image Processor
DIGIC 4
Sensors
Digital level metre
Sensor Resolution
18.0 Megapixel
Max Video Resolution
1920 x 1080
Lens System
Zoom lens - 7.5x zoom - 18 - 135 mm - f/3.5-5.6 Canon EF-S
Focus Adjustment
Automatic, manual
Min Focus Distance
45 cm
Image Stabiliser
Optical
Camera Flash
Pop-up flash
Viewfinder
Optical - fixed eye-level pentaprism
Display
LCD display - 3"
Supported Battery
1 x Li-ion rechargeable battery (included)
Composite video/audio, HDMI, USB 2.0
Microsoft Certification
Compatible with Windows 7
14.5 cm x 7.9 cm x 10.6 cm
0.68 kg
Lens Included
Sensor Resolution
18.0 Megapixel
Optical Sensor Type
CMOS
Total Pixels
19,000,000 pixels
Effective Sensor Resolution
18,000,000 pixels
Optical Sensor Size
14.9 x 22.3mm
Field of View Crop Factor
1.6
ISO (Max)
12800
Sensor Dust Reduction
Sensor Features
EOS Integrated Cleaning System, Self Cleaning Sensor Unit
Optical Zoom
7.5x
Image Processor
DIGIC 4
Image Stabiliser
Optical
Face Detection
Sensors
Digital level metre
Print Standard
Direct print, DPOF support, Exif Print support, PictBridge support
Auto Focus
TTL contrast and phase detection
Auto Focus Points (Zones) Qty
9
Digital Video Format
MOV
Image Recording Format
JPEG, RAW, RAW + JPEG
1920 x 1080
Exposure & White Balance
Light Sensitivity
ISO auto, ISO 12800, ISO 100-6400
Exposure Metering
Evaluative, partial (6.5%), multi-segment, centre-weighted, spot
Exposure Metering Zones
63
Exposure Modes
Programme, bulb, automatic, manual, aperture-priority, shutter-priority, E-TTL II program flash
Shooting Programs
Landscape, portrait mode, close-up, night portrait, sports mode
Special Effects
Neutral, Custom Effect, Faithful, monochrome, landscape, portrait
White Balance
Custom, automatic, presets
White Balance Presets
Fluorescent, cloudy, tungsten light, Flash, daylight, shade
Max Shutter Speed
1/8000 sec
Min Shutter Speed
30 sec
Exposure Compensation
±5 EV range, in 1/2 or 1/3 EV steps
Auto Exposure Bracketing
3 steps in 1/2 or 1/3 EV steps
White Balance Bracketing
X-sync Speed
1/250sec
Exposure Range
EV 0-20 (ISO 100)
Lens System
Focal Length Equivalent to 35mm Camera
29 - 216mm
Focus Adjustment
Automatic, manual
Min Focus Distance
45 cm
Max View Angle
74.3 degree(s)
Zoom Adjustment
Manual
Lens Construction
12 groups / 16 elements
Filter Size
67 mm
Lens Mounting Type
Canon EF
UD glass, internal focusing system
Camera Flash
Camera Flash
Pop-up flash
Guide Number (m / ISO 100)
13
Flash Modes
Fill-in mode, E-TTL, rear curtain sync, auto mode, flash OFF mode, red-eye reduction
AF illuminator, flash +/- compensation
Additional Features
Continuous Shooting Speed
3 frames per second, 5.3 frames per second
Self-Timer Delay
10 sec, 2sec
Flash Terminal
Hot shoe
Additional Features
RGB primary colour filter, digital noise reduction, depth-of-field preview button, camera orientation detection, histogram display, highlight tone priority, LCD live view mode, highlight point display, face detection, Auto Lighting Optimizer, in-camera RAW processing, peripheral illumination correction
Viewfinder
Viewfinder Type
Optical Viewfinder Field Coverage
96%
Optical Viewfinder Magnification
0.95x
Optical Viewfinder Dioptric Correction Range
-3 to +1
Viewfinder Information
Shutter speed, AE lock, AF-in-focus, flash charge completion, red-eye reduction, aperture, white balance, battery status, high-speed sync indicator, flash compensation on/off, highlight tone priority, ISO sensitivity, memory card status, FE lock
Display
3" LCD display
Resolution
1,040,000 pixels
Display Form Factor
Rotating
Display Features
Display brightness control
Microphone
Microphone Operation Mode
Mono
Connector Type
Composite video/audio output , USB , HDMI , Microphone
Software
Software
Drivers & Utilities, Canon PhotoStitch, Canon ZoomBrowser EX, Canon ImageBrowser, Canon Remote Capture, Canon Digital Photo Professional
Battery charger, dust cap, body cap, lens cap, neck strap, USB cable, eyecup, audio / video cable
Body Material
Aluminium, fibreglass-reinforced polycarbonate resin
Battery Type
Canon LP-E6
Details
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card
Image Storage
RAW 5184 x 3456 , RAW 3888 x 2592 , RAW 2592 x 1728 , JPEG 5184 x 3456 , JPEG 3456 x 2304 , JPEG 2592 x 1728 , JPEG 1920 x 1280 , JPEG 720 x 480 , JPEG 4608 x 3456 , JPEG 3072 x 2304 , JPEG 2304 x 1728 , JPEG 1696 x 1280 , JPEG 640 x 480 , JPEG 5184 x 2912 , JPEG 3456 x 1944 , JPEG 2592 x 1456 , JPEG 1920 x 1080 , JPEG 720 x 400 , JPEG 3456 x 3456 , JPEG 2304 x 2304 , JPEG 1728 x 1728 , JPEG 1280 x 1280 , JPEG 480 x 480
Video Capture
MOV - 1920 x 1080 - 30 fps , MOV - 1920 x 1080 - 25 fps , MOV - 1920 x 1080 - 24 fps , MOV - 1280 x 720 - 60 fps , MOV - 1280 x 720 - 50 fps , MOV - 640 x 480 - 60 fps , MOV - 640 x 480 - 50 fps , MOV - 640 x 480 - 30 fps , MOV - 640 x 480 - 24 fps
14.5 cm
7.9 cm
10.6 cm
0.68 kg
Scroll to top
