BT.com
Wishlist
Canon EOS 600D SLR Camera - 18MP - 3.0 LCD - inc Canon EF-S 18-55mm IS II Lens
Free delivery
Delivery
Standard Due date unavailable
Canon EOS 600D JLP advert/video
With class-leading 18-megapixel resolution, user-friendly design, and the entire EOS family of lenses and accessories at your disposal, the EOS 600D lets nothing stand in the way of your photography
An APS-C sized, 18-megapixel CMOS sensor captures images that are packed with detail and clarity. Such high-resolution allows large print sizes and the flexibility to crop pictures for alternative compositions.
At the heart of the Canon EOS 600D is a 14-bit DIGIC 4 image processor that provides exceptional color reproduction, smooth tonal gradation and tight control over noise. Scene intelligent auto analyzes each scene in detail and picks the right camera settings each and every time, leaving you free to concentrate on what's important - your photography. The EOS 600D's on-screen feature guide provides descriptions of many of the camera's functions, as well as advice on how to use them.
Your EOS adventure starts here
18 MP APS-C CMOS sensor
ISO 100-6400 sensitivity
An ISO range of 100-6400, extendable to ISO 12,800, enables high-quality hand-held shooting in low-light conditions, without the need for flash.
14-bit image processing
At the heart of the Canon EOS 600D is a 14-bit DIGIC 4 image processor that provides exceptional colour reproduction, smooth tonal gradation and tight control over noise.
Scene Intelligent Auto mode
Scene Intelligent Auto analyzes each scene in detail and picks the right camera settings each and every time, leaving you free to concentrate on what's important - your photography.
On-screen Feature Guide
The EOS 600D's on-screen Feature Guide provides descriptions of many of the camera's functions, as well as advice on how to use them.
Full-HD EOS Movie
Shoot Full-HD video with manual control over frame rate, exposure and sound. Video Snapshot technology allows short clips of 2, 4 or 8 sec to be merged into a single movie file, for footage that looks like it was edited professionally, while Movie Digital Zoom permits 3-10x magnification.
9-point wide-area AF and iFCL metering
Nine AF points, including one central cross-type sensor, spread out across the frame for swift, accurate focusing, even with off-centre subjects. 63-zone iFCL metering ensures accurate exposures time after time.
1,040k-dot vari-angle 7.7cm (3.0") screen
Shoot from unique angles with a 7.7cm (3.0") 3:2 Clear View LCD screen, containing 1,040,000 dots for increased clarity.
Basic+
Basic+ technology allows photographers to customize basic auto settings according to lighting conditions or ambience.
Creative Filter Effects
Creative Filter Effects can be applied to Raw and JPEG files post capture, including Toy Camera, Soft Focus, Miniature, Grainy Black & White and Fish Eye simulations.
Built-in wireless flash control
An integrated wireless Speedlite flash controller and Easy Wireless technology allow off-camera TTL flash without the need for extra accessories.
Use with all EF and EF-S lenses
The EOS 600D is supported by the complete system: flashguns, remote releases and over 60 lenses trusted by professional photographers the world over.
Canon EOS 600D - digital camera EF-S 18-55mm IS II lens
Digital camera - 1080p - SLR with Live View mode, movie recording
Lens Included
Memory Card Slot
SD card
Image Processor
DIGIC 4
Sensor Resolution
18.0 Megapixel
Max Video Resolution
1920 x 1080
Lens System
Zoom lens - 3 x zoom - 18 - 55 mm - f/3.5-5.6 II Canon EF-S
Focus Adjustment
Automatic, manual
Min Focus Distance
25 cm
Image Stabiliser
Optical
Camera Flash
Pop-up flash
Viewfinder
Optical - eye-level mirror pentaprism
Display
LCD display - 3"
Supported Battery
1 x Li-ion rechargeable battery ( included )
Interfaces Provided
Composite video/audio, HDMI, USB 2.0
Microsoft Certification
Compatible with Windows 7
13.3 cm x 8 cm x 10 cm
570 g
Lens Included
Sensor Resolution
18.0 Megapixel
Optical Sensor Type
CMOS
Total Pixels
18,700,000 pixels
Effective Sensor Resolution
18,000,000 pixels
Optical Sensor Size
14.9 x 22.3mm
Field of View Crop Factor
1.6
ISO (Max)
12800
Sensor Dust Reduction
Sensor Features
EOS Integrated Cleaning System, Self Cleaning Sensor Unit
Optical Zoom
3 x
Image Processor
DIGIC 4
Image Stabiliser
Optical
Face Detection
Print Standard
Direct print, DPOF support, Exif Print support, PictBridge support
Auto Focus
TTL phase detection
Auto Focus Points (Zones) Qty
9
Digital Video Format
MOV
Image Recording Format
JPEG, RAW, RAW + JPEG
1920 x 1080
Interfaces Provided
Exposure & White Balance
Light Sensitivity
ISO 12800, ISO 100-6400, ISO auto (100-6400)
Exposure Metering
Evaluative, partial (9%), centre-weighted, spot (4%)
Exposure Metering Zones
63
Exposure Modes
Programme, depth-of-field, bulb, automatic, manual, aperture-priority, shutter-priority
Shooting Programs
Landscape, portrait mode, action, close-up, night scene
Special Effects
Neutral, Faithful, monochrome, landscape, portrait
White Balance
Custom, automatic, presets
White Balance Presets
Fluorescent, cloudy, tungsten light, Flash, daylight, shade
Max Shutter Speed
1/4000 sec
Min Shutter Speed
30 sec
Exposure Compensation
±5 EV range, in 1/2 or 1/3 EV steps
Auto Exposure Bracketing
3 steps in 1/2 or 1/3 EV steps
White Balance Bracketing
X-sync Speed
1/200sec
Exposure Range
EV 1-20 ( ISO 100 )
Lens System
Focal Length Equivalent to 35mm Camera
29 - 88mm
Focus Adjustment
Automatic, manual
Min Focus Distance
25 cm
Max View Angle
74.3 degree(s)
Zoom Adjustment
Manual
Lens Construction
9 groups / 11 elements
Filter Size
58 mm
Lens Mounting Type
Canon EF
Aspherical lens
Camera Flash
Camera Flash
Pop-up flash
Guide Number (m / ISO 100)
13
Flash Modes
Fill-in mode, rear curtain sync, auto mode, flash OFF mode, red-eye reduction
AF illuminator, flash +/- compensation, wireless off-camera control
Additional Features
Continuous Shooting Speed
3.7 frames per second
Self Timer Delay
10 sec, 2sec
Flash Terminal
Hot shoe
Additional Features
RGB primary colour filter, auto power save, digital noise reduction, depth-of-field preview button, histogram display, AE lock, AF lock, FE lock, Scene Detection Technology, highlight tone priority, highlight point display, Dust Delete Data system, Live Face detection AF mode, face detection, built-in help guide, Auto Lighting Optimizer, peripheral illumination correction, Eye-Fi Card Ready, Picture Style Auto, Scene Intelligent Auto technology
Viewfinder
Viewfinder Type
Optical Viewfinder Field Coverage
95%
Optical Viewfinder Magnification
0.85x
Optical Viewfinder Dioptric Correction Range
-3 to +1
Viewfinder Frames
Autofocus frame
Viewfinder Information
Shutter speed, exposure compensation, AE lock, AF-in-focus, flash charge completion, red-eye reduction, aperture, white balance, exposure bracketing, high-speed sync indicator, flash compensation on/off, highlight tone priority, ISO sensitivity, memory card status, FE lock
Display
3" LCD display
Resolution
1,040,000 pixels
Display Form Factor
Rotating
Display Features
Display brightness control
Microphone
Microphone Operation Mode
Mono
Connector Type
1 x USB 2.0 , 1 x composite video/audio output , 1 x HDMI output , 1 x remote control , 1 x microphone
Software
Software
Drivers & Utilities, Canon PhotoStitch, Canon ZoomBrowser EX, Canon ImageBrowser, Canon Remote Capture, Canon Digital Photo Professional
Battery charger, dust cap, body cap, lens cap, neck strap, USB cable, eyecup, audio / video cable
Body Material
Stainless steel, polycarbonate resin
Battery Type
Canon LP-E8
Details
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card
Image Storage
RAW 5184 x 3456 , JPEG 5184 x 3456 , JPEG 3456 x 2304 , JPEG 2592 x 1728 , JPEG 1920 x 1280 , JPEG 720 x 480
Video Capture
MOV - 1920 x 1080 - 30 fps , MOV - 1920 x 1080 - 25 fps , MOV - 1920 x 1080 - 24 fps , MOV - 1280 x 720 - 60 fps , MOV - 1280 x 720 - 50 fps , MOV - 640 x 480 - 60 fps , MOV - 640 x 480 - 50 fps
13.3 cm
8 cm
10 cm
570 g
Accessories
Canon LP-E8 - camera battery - Li-Ion
Quicklinx: 6LTQ | In Stock
£46.26
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
4* Canon EOS 600D
Reviewed by Anonymous on 11/09/2012
Now that you have reduced the price by 1.8% I find this Camera irresistable
Scroll to top
