Click to visit BT.com
BT.com
Wishlist
Canon EOS 1100D Digital SLR - EF-S 18-55mm DC III lens - black
Quicklinx: 8CJ4WS00
Mfr#: 5161B030AA
Essential accessories
Canon EOS 1100D - Take the first step
Advanced, compact and affordable: your first steps into the world of DSLR photography, made simple with Canon EOS 1100D.
- Superior 12-megapixel image quality
- On-screen Feature Guide
- Creative Auto and Basic+
- HD video capture
- ISO 100-6400 sensitivity
- Wide-area 9-point AF system
- 63-zone iFCL exposure metering
- 6.8cm (2.7"), 230,000-dot screen
- Use with all EF and EF-S lenses
12-megapixel resolution
Step up to DSLR image quality with a 12-megapixel APS-C-sized sensor. A 14-bit DIGIC 4 image processor provides up to 3.2fps continuous shooting and images that are packed with detail and tonal range.
Intuitive, on-screen feature guide
The EOS 1100D's Feature Guide provides descriptions of many of the camera's functions, as well as advice on how to use them in your own photography.
Easy to use Scene modes and Basic+
Theme-based Scene modes automatically pick the most suitable exposure, focus and drive-mode settings for the subject being photographed, while Creative Auto mode portrays adjustable functions in an easy to understand way. With Canon's Basic + technology, the look and feel of these basic auto modes can be fine-tuned according to ambience and lighting type.
HD EOS Movie mode
Shoot stunning HD video at 25 or 30fps, with automatic exposure control leaving you free to concentrate on the action. Footage can be edited on your PC or Mac, or played directly on an HD TV via the camera's HDMI connection.
Low-light shooting without flash is possible thanks to the EOS 1100D's ISO 100-6400 sensitivity range. The camera's 14-bit DIGIC 4 processor helps to control noise and maintain image quality.
The EOS 1100D focuses quickly and accurately on static and moving subjects, thanks to nine AF points, spread out across the frame. A central cross-type AF point is sensitive to both horizontal and vertical lines.
Advanced iFCL exposure metering dissects a scene into 63-zones before analyzing it to find the perfect combination of shutter speed, aperture and ISO.
6.8cm (2.7"), 230,000-dot LCD screen
Compose and review images on a large 230,000-dot LCD screen, which also provides access to the camera's menu system and Quick Control Screen.
The EOS 1100D is supported by the complete range of EOS lenses and accessories: flashguns, remote releases and a system of more than 60 lenses trusted by professional photographers the world over.
Canon EOS 1100D - digital camera EF-S 18-55mm DC III lens
Digital camera - 720p - SLR with Live View mode, movie recording
Lens Included
Memory Card Slot
SD card
Image Processor
DIGIC 4
Sensor Resolution
12.0 Megapixel
Max Video Resolution
1280 x 720
Lens System
3 x zoom lens - 18 - 55 mm - f/3.5-5.6 III Canon EF-S
Focus Adjustment
Automatic, manual
Camera Flash
Pop-up flash
Viewfinder
Optical - eye-level mirror pentaprism
Display
LCD display - 2.7"
Supported Battery
1 x Li-ion rechargeable battery ( included )
Interfaces Provided
Composite video/audio, HDMI, USB 2.0
Microsoft Certification
Compatible with Windows 7
13 cm x 7.8 cm x 10 cm
495 g
Lens Included
Enclosure Colour
Sensor Resolution
12.0 Megapixel
Optical Sensor Type
CMOS
Total Pixels
12,600,000 pixels
Effective Sensor Resolution
12,000,000 pixels
Optical Sensor Size
14.7 x 22.2mm
Field of View Crop Factor
1.6
ISO (Max)
6400
Optical Zoom
3 x
Image Processor
DIGIC 4
Face Detection
Print Standard
Direct print, DPOF support, Exif Print support, PictBridge support
Auto Focus
TTL phase detection
Auto Focus Points (Zones) Qty
9
Digital Video Format
H.264, MOV
Image Recording Format
JPEG, RAW, RAW + JPEG
1280 x 720
Interfaces Provided
Exposure & White Balance
Light Sensitivity
ISO 100-6400, ISO auto (100-6400)
Exposure Metering
Evaluative, partial (10%), centre-weighted
Exposure Metering Zones
63
Exposure Modes
Programme, depth-of-field, bulb, automatic, manual, aperture-priority, shutter-priority
Shooting Programs
Landscape, portrait mode, close-up, night portrait, sports mode
Special Effects
Neutral, Faithful, monochrome, landscape, portrait
White Balance
Custom, automatic, presets
White Balance Presets
Fluorescent, cloudy, tungsten light, Flash, daylight, shade
Max Shutter Speed
1/4000 sec
Min Shutter Speed
30 sec
Exposure Compensation
±5 EV range, in 1/2 or 1/3 EV steps
Auto Exposure Bracketing
3 steps in 1/2 or 1/3 EV steps
White Balance Bracketing
X-sync Speed
1/200sec
Exposure Range
EV 1-20 ( ISO 100 )
Lens System
Focal Length Equivalent to 35mm Camera
29 - 88mm
Focus Adjustment
Automatic, manual
Max View Angle
74.3 degree(s)
Zoom Adjustment
Manual
Filter Size
58 mm
Lens Mounting Type
Canon EF
Camera Flash
Camera Flash
Pop-up flash
Guide Number (m / ISO 100)
9.2
Flash Modes
Fill-in mode, rear curtain sync, auto mode, flash OFF mode, red-eye reduction
AF illuminator, flash +/- compensation
Additional Features
Continuous Shooting Speed
2 frames per second, 3 frames per second
Self Timer Delay
10 sec, 2sec
Flash Terminal
Hot shoe
Additional Features
RGB primary colour filter, auto power save, digital noise reduction, depth-of-field preview button, histogram display, AE lock, AF lock, FE lock, highlight tone priority, LCD live view mode, highlight point display, Dust Delete Data system, built-in help guide, Auto Lighting Optimizer, peripheral illumination correction, Eye-Fi Card Ready
Viewfinder
Viewfinder Type
Optical Viewfinder Field Coverage
95%
Optical Viewfinder Magnification
0.8x
Optical Viewfinder Dioptric Correction Range
-2.5 to +0.5
Viewfinder Frames
Autofocus frame
Viewfinder Information
Shutter speed, exposure compensation, AE lock, AF-in-focus, flash charge completion, red-eye reduction, aperture, white balance, high-speed sync indicator, flash compensation on/off, highlight tone priority, ISO sensitivity, memory card status
Display
2.7" LCD display
Resolution
230,400 pixels
Display Form Factor
Built-in
Display Features
Display brightness control
Microphone
Microphone Operation Mode
Mono
Connector Type
1 x USB 2.0 , 1 x composite video/audio output , 1 x HDMI output , 1 x remote control
Software
Software
Drivers & Utilities, Canon PhotoStitch, Canon ZoomBrowser EX, Canon ImageBrowser, Canon Remote Capture, Canon Digital Photo Professional, Canon Picture Style Editor
Battery charger, body cap, neck strap, USB cable, eyecup, audio / video cable
Body Material
Stainless steel, polycarbonate resin
Battery Type
Canon LP-E10
Details
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card
Image Storage
RAW 4272 x 2848 , JPEG 4272 x 2848 , JPEG 3088 x 2056 , JPEG 2256 x 1504 , JPEG 1920 x 1280 , JPEG 720 x 480
Video Capture
MOV - 1280 x 720 - 30 fps , MOV - 1280 x 720 - 25 fps
13 cm
7.8 cm
10 cm
495 g
