BT.com
Wishlist
Canon EOS 1000D - Digital camera - SLR - 10.1 Mpix - body only - supported memory: SD, SDHC
Delivery
Standard Due date unavailable
With a 10.1 Megapixel CMOS sensor and technology inherited from Canon's professional models, the EOS 1000D offers EOS imaging power in an affordable, easy-to-use package.
For dramatic mid-action shots, the EOS 1000D allows continuous shooting of large JPEG images at speeds of up to 3 frames per second, until the memory card is full. With a card, this lets you shoot up to 514 images without a pause.
A wide-area Auto Focus system uses 7 separate focusing points to lock onto subjects fast. The central focus point enables focusing even under low-light or low-contrast conditions.
Canon's built-in dust prevention system guards images against the effects of dust in three ways: reducing dust generated inside the camera, shaking dust from the sensor each time the camera is turned on or off, and mapping stubborn dust spots for removal with the provided Digital Photo Professional software.
Canon EOS 1000D - digital camera - body only
Digital camera - SLR with Live View mode
Lens Included
Body only
Memory Card Slot
SD card
Image Processor
DIGIC III
Sensor Resolution
10.1 Megapixel
Camera Flash
Pop-up flash
Viewfinder
Optical - eye-level mirror pentaprism
Display
LCD display - 2.5"
Supported Battery
1 x Li-ion rechargeable battery - 1080 mAh (included)
Interfaces Provided
Composite video/audio, USB 2.0
Microsoft Certification
Certified for Windows Vista
12.6 cm x 6.2 cm x 9.8 cm
450 g
Lens Included
Body only
Sensor Resolution
10.1 Megapixel
Optical Sensor Type
CMOS
Total Pixels
10,500,000 pixels
Effective Sensor Resolution
10,100,000 pixels
Optical Sensor Size
14.8 x 22.2mm
Field of View Crop Factor
1.6
ISO (Max)
1600
Sensor Dust Reduction
Sensor Features
EOS Integrated Cleaning System, Self Cleaning Sensor Unit
Image Processor
DIGIC III
Print Standard
Direct print, DPOF support, PictBridge support
Auto Focus
TTL phase detection
Auto Focus Points (Zones) Qty
7
Image Recording Format
JPEG, RAW, RAW + JPEG
Interfaces Provided
Exposure & White Balance
Light Sensitivity
ISO 100, ISO 800, ISO 400, ISO 200, ISO 1600, ISO auto (100-800)
Exposure Metering
Evaluative, partial (10%), centre-weighted
Exposure Metering Zones
35
Exposure Modes
Programme, depth-of-field, bulb, automatic, manual, aperture-priority, shutter-priority
Shooting Programs
Landscape, portrait mode, close-up, night portrait, sports mode
Special Effects
Monochrome
White Balance
Custom, automatic, presets
White Balance Presets
Fluorescent, cloudy, tungsten light, Flash, daylight, shade
Max Shutter Speed
1/4000 sec
Min Shutter Speed
30 sec
Exposure Compensation
±2 EV range, in 1/2 or 1/3 EV steps
Auto Exposure Bracketing
3 steps in 1/2 or 1/3 EV steps
White Balance Bracketing
X-sync Speed
1/200sec
Exposure Range
EV 1-20 (ISO 100)
Lens System
Lens Mounting Type
Canon EF-S
Camera Flash
Camera Flash
Pop-up flash
Guide Number (m / ISO 100)
13
Flash Modes
Fill-in mode, rear curtain sync, auto mode, flash OFF mode, red-eye reduction
AF illuminator, flash +/- compensation, flash exposure bracketing
Additional Features
Continuous Shooting Speed
3 frames per second, 1.5 frames per second
Self Timer Delay
10 sec, 2sec
Flash Terminal
Hot shoe
Additional Features
RGB primary colour filter, auto power save, depth-of-field preview button, camera orientation detection, histogram display, AE lock, AF lock, FE lock, LCD live view mode, highlight point display
Viewfinder
Viewfinder Type
Optical Viewfinder Field Coverage
95%
Optical Viewfinder Magnification
0.81x
Optical Viewfinder Dioptric Correction Range
-3 to +1
Viewfinder Frames
Autofocus frame
Viewfinder Information
Shutter speed, exposure compensation, AE lock, AF-in-focus, flash charge completion, red-eye reduction, aperture, white balance, high-speed sync indicator, flash compensation on/off, ISO sensitivity, AF lock, memory card status
Display
2.5" LCD display
Resolution
230,000 pixels
Display Form Factor
Built-in
Display Features
Display brightness control
Connector Type
1 x USB , 1 x composite video output , 1 x remote control
Software
Software
Drivers & Utilities, Canon PhotoStitch, Canon ZoomBrowser EX, Canon ImageBrowser, Canon Digital Photo Professional
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
Carrying strap, battery charger, body cap, USB cable, eyecup, video cable
Body Material
Plastic, stainless steel
Battery Type
Canon LP-E5
Details
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDHC Memory Card
Image Storage
JPEG 3888 x 2592 , JPEG 2816 x 1880 , JPEG 1936 x 1288 , RAW 3888 x 2592 , RAW 1936 x 1288
12.6 cm
6.2 cm
9.8 cm
450 g
Accessories
£354.00
Canon EF 100 mm - f/2.0 USM Telephoto lens
Quicklinx: 5B2R | In Stock
£429.90
Scroll to top
