Click to visit BT.com
BT.com
Wishlist
Canon EF-S 17-85mm f/4.0-5.6 IS USM Lens
Quicklinx: 8NQJWS00
Mfr#: 9517A008BA
Essential accessories
Canon EF-S 17-85mm f/4-5.6 IS USM
One lens. Many possibilities.
Real freedom of framing in a lightweight, compact and fast-focusing lens. The EF-S 17-85mm f/4-5.6 IS USM is an excellent all-purpose lens for EF-S mount EOS cameras.
  • Exceptional zoom range for all EF-S mount bodies
  • Superb image quality
  • Lightweight and compact
  • Image Stabilizer - up to 3 stops compensation
  • Fast near-silent USM AF
  • Super Spectra coatings
  • Circular aperture
  • Optional exclusive lens hood
The all purpose lens with IS
The EF-S 17-85mm f/4-5.6 IS USM provides an effective focal length range of approximately 27-136mm in 35mm format. This provides plenty of framing options, making it the perfect all-rounder lens that allows you to express your creativity in a vast range of shooting situations.
Light and fast
The small size and low weight of the EF-S 17-85mm f/4-5.6 IS USM makes it ideal for fast moving photography and travel, where it is not practical to carry around a heavy bag of kit. Its ring-type USM works in harmony with EF-S mount EOS cameras to provide super-fast, precision auto focusing and predictive tracking - with full manual override available at any time.
Go steady
Image Stabilizer technology compensates for a full three stops, giving the lens an effective maximum aperture of f1.4-2.0; excellent for hand-held and low light photography.
Designed for digital
Designed specifically for digital photography, the lens has specially shaped lens elements and Super Spectra coatings to suppress ghosting and flare, which can be caused by reflections off the camera sensors. An exclusive optional lens hood can further reduce the incidence of flare.
Background blur
A circular aperture provides a pleasing background blur when shooting with a wide aperture; ideal for creating a sense of depth and getting your subject or model to stand out from the background.
Canon EF-S zoom lens - 17 mm - 85 mm
Lens System
Zoom lens
Intended For
35mm SLR, digital SLR
Mounting Type
Canon EF-S
Lens Aperture
F/4.0-5.6
Focal Length
17 mm - 85 mm
Optical Zoom
5 x
Min Focus Distance
35 cm
Focus Adjustment
Automatic, manual
Lens Construction
12 groups / 17 elements
Special Functions
Zoom
Filter Size
67 mm
Length
9.2 cm
475 g
EOS 1000D, 20D, 20Da, 300D, 30D, 350D, 400D, 40D, 450D, 500D, 50D, 7D, Digital Rebel, Digital Rebel XT, Digital Rebel XTi, Kiss Digital, Kiss Digital N, Kiss Digital X, Kiss F, Kiss X2, Kiss X3, Rebel T1i, Rebel XS, Rebel XSi
Length
9.2 cm
Diameter
7.9 cm
475 g
Lens System
Zoom lens
Special Functions
Zoom
Intended For
Focal Length
17 mm - 85 mm
Lens Aperture
F/4.0-5.6
Minimum Aperture
F/22 - f/32
Focal Length Equivalent to 35mm Camera
27 - 136mm
Optical Zoom
5 x
Magnification
0.2
Image Stabiliser
Optical
Min Focus Distance
35 cm
Focus Adjustment
Automatic, manual
Zoom Adjustment
Manual
Max View Angle
78.5 degree(s)
Min View Angle
18.3 degree(s)
Lens Construction
Filter Size
67 mm
Diaphragm Blades
6
Lens Coating
Mounting Type
Canon EF-S
Internal focusing system, Ultrasonic Motor (USM), full-time manual focusing, aspherical lens
Dust cap, lens cap
Canon EOS 1000D, 20D, 20Da, 300D, 30D, 350D, 400D, 40D, 450D, 500D, 50D, 7D, Digital Rebel, Digital Rebel XT, Digital Rebel XTi, Kiss Digital, Kiss Digital N, Kiss Digital X, Kiss F, Kiss X2, Kiss X3, Rebel T1i, Rebel XS, Rebel XSi
