BT.com
Wishlist
Canon EF-S 15-85 mm f/3.5-5.6 IS USM Lens
Canon EF-S 15-85 mm f/3.5-5.6 IS...
Cashback
£653.29
Cashback
£50 Cashback Available!
23 in stock
£653.29
Add to wishlist
Delivery
Standard 1-3 working days
Canon EF-S 15-85mm f/3.5-5.6 IS USM
The high performance, all-round standard zoom lens.
Combining a extensive zoom range featuring wide angle and telephoto plus a 4-stop Image Stabilizer, the EF-S 15-85mm f/3.5-5.6 IS USM provides outstanding performance and flexibility.
  • High performance all-purpose 5.6x 24-136mm equivalent EF-S standard zoom
  • 4 stop Image Stabilizer
  • Automatic panning and tripod detection
  • 0.35m close focusing
  • UD and aspherical lenses
  • Super Spectra coatings
  • 7-blade aperture
  • Optional lens hood
High performance flexible wide angle zoom
With an effective focal length range of approximately 24-136mm (35 mm equivalent), the EF-S 15-85mm f/3.5-5.6 IS USM is a lens that delivers outstanding flexibility while delivering remarkable image quality. With its wider angle than many comparable lenses, it captures more of the scene and adds a greater sense of space and perspective to your photography.
Image Stabilizer
The EF-S 15-85mm f/3.5-5.6 IS USM features Canon's 4-stop Image Stabilizer (IS). Ideal for handheld work, the IS function allows the use of shutter speeds up to 4 stops slower without causing image blur. The Image Stabilizer helps when shooting in low light conditions or from moving vehicles.
Looks as good as it performs
The EF-S 15-85mm f/3.5-5.6 IS USM features a textured exterior finish for a high quality look and feel, that matches your EOS camera.
Ultra fast, ultra quiet auto focus
The ring USM (Ultrasonic motor) uses ultrasonic frequency vibrations to drive responsive, near-silent high speed auto focus. The ring type USM allows full time manual focus override without having to switch out of AF, for a greater level of usability.
Lens elements are treated with Canon's Super Spectra lens coating which suppresses flare and prevents ghosting - which is more likely to occur with digital cameras due to reflection off the image sensor. Canon's Super Spectra coating also helps achieve true colour balance and increase contrast for vivid hi-fidelity images.
Creative background blur
A 7 blade circular aperture enables photographers to achieve a beautiful background blur; ideal for isolating your subject from the background.
Canon EF-S zoom lens - 15 mm - 85 mm
Lens System
Zoom lens
Intended For
35mm SLR, digital SLR
Mounting Type
Canon EF-S
Lens Aperture
F/3.5-5.6
Focal Length
15 mm - 85 mm
Optical Zoom
5.6 x
Min Focus Distance
35 cm
Focus Adjustment
Automatic, manual
Lens Construction
12 groups / 17 elements
Special Functions
Zoom
Filter Size
72 mm
Length
8.8 cm
0.58 kg
EOS 1000D, 20D, 20Da, 300D, 30D, 350D, 400D, 40D, 450D, 500D, 50D, 7D, Digital Rebel, Digital Rebel XT, Digital Rebel XTi, Kiss Digital, Kiss Digital N, Kiss Digital X, Kiss F, Kiss X2, Kiss X3, Rebel T1i, Rebel XS, Rebel XSi
Length
8.8 cm
Diameter
8.2 cm
0.58 kg
Lens System
Zoom lens
Special Functions
Zoom
Intended For
Focal Length
15 mm - 85 mm
Lens Aperture
F/3.5-5.6
Minimum Aperture
F/22 - f/38
Focal Length Equivalent to 35mm Camera
24 - 136mm
Optical Zoom
5.6 x
Magnification
0.21
Image Stabiliser
Optical
Min Focus Distance
35 cm
Focus Adjustment
Automatic, manual
Zoom Adjustment
Manual
Max View Angle
84.5 degree(s)
Min View Angle
18.4 degree(s)
Lens Construction
Filter Size
72 mm
Diaphragm Blades
7
Lens Coating
Mounting Type
Canon EF-S
UD glass, internal focusing system, Ultrasonic Motor (USM), aspherical lens
Dust cap, lens cap
Canon EOS 1000D, 20D, 20Da, 300D, 30D, 350D, 400D, 40D, 450D, 500D, 50D, 7D, Digital Rebel, Digital Rebel XT, Digital Rebel XTi, Kiss Digital, Kiss Digital N, Kiss Digital X, Kiss F, Kiss X2, Kiss X3, Rebel T1i, Rebel XS, Rebel XSi
Scroll to top
