Click to visit BT.com
BT.com
Wishlist
Canon CanoScan LiDE 700F
5.0*
Quicklinx: 5HZBWS00
Mfr#: 3297B010AA
With its ingenious 3-way design and 180° lid, the LiDE 700F brings high resolution scanning to work spaces of all sizes. For exceptional detail and enlargements, scan 35mm film at up to 9600dpi.
A LiDE scanner with CIS sensor provides a winning combination of incredibly high resolution scans and low energy consumption. Powered by a single USB cable, connected to a computer, the LiDE 700F has no need for an additional power cable, making it truly portable and space saving.
Incredibly high resolution scans from 35mm film are possible thanks to a dedicated clip-on film scanning unit. This means massive enlargements and intricately detailed prints can be achieved from your 35mm film negatives/positives.
  • LiDE scanner with CIS sensor
  • Innovative 3-way design
    The LiDE 700F's ingenious 3-way design, with flip-out stand, allows it to be used in portrait, landscape or vertical positions ÔÇô this means that it fits into almost any workspace.
  • 9600 x 9600 dpi film scanning
  • 48-bit input
    Achieve life-like color reproduction with 48bit input, which can replicate billions of separate colors ÔÇô enhancing your color scans with amazingly accurate depth and tone.
  • Auto scan mode
    With one click, Auto Scan Mode automatically recognizes the type and format of your original, then scans and saves using suitable settings. One touch operation saves you time by eliminating the need for lengthy settings configuration.
  • Configurable EZ buttons
    The four configurable EZ buttons enable fast, convenient operation for PDF, Copy, Scan, and Email functions. You can choose the settings and assign them to each button ÔÇô once these configurations are saved your scanner will work exactly as you need it to.
  • QARE dust and scratch removal
    QARE stands for Quick Automatic Retouching and Enhancement technology and does just that. Reflective documents and old photographs can now be easily enhanced and printed using a photo quality printer. The LiDE 700F automatically detects and removes dust from your scans for pristine results that save you time by removing the hassle of post-scan retouching.
Canon CanoScan LiDE 700F - flatbed scanner
Flatbed scanner - desktop
Interface Type
USB 2.0
Scan Element Type
Contact Image Sensor (CIS)
Light Source
RGB LED array
Max Supported Document Size
216 x 297 mm
Input Type
Grayscale / Color Depth
48-bit colour
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 48-bit colour
Optical Resolution
9600 dpi x 9600 dpi
Interpolated Resolution
19200 dpi x 19200 dpi
Scan Speed
2.4 ms / line (colour)
Max Document Size
216 mm x 297 mm
Supported Document Type
Plain paper, film
Microsoft Windows 2000 Professional, Microsoft Windows XP, Apple MacOS X 10.4, Apple MacOS X 10.3.9, Microsoft Windows Vista, Apple MacOS X 10.5
Microsoft Certification
Certified for Windows Vista
29.2 cm x 40.9 cm x 4.4 cm
2.1 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
216 x 297 mm
Scanner
Input Type
Grayscale Depth (External)
Colour Depth
48-bit colour
Colour Depth (External)
48-bit colour
Optical Resolution
9600 dpi x 9600 dpi
Scan Element Type
Bulb / Light Source Type
RGB LED array
Scan Speed
Scanner Speed Details
2.4 ms/line - colour - 300 dpi , 2.3 ms/line - black & white - 300 dpi , 33.5 ms/line - colour - 4800 dpi , 11.3 ms/line - black & white - 4800 dpi , 2.3 ms/line - greyscale - 300 dpi , 11.3 ms/line - greyscale - 4800 dpi
Scanner Features
Powered by USB port
Media Handling
Max Document Size
216 mm x 297 mm
Plain paper, film
USB 2.0 - Type B
Film adaptor
1 x USB cable
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
Power Consumption Operational (Standby)
2.5 Watt ( 1.5 Watt )
Software Included
Drivers & Utilities, ScanGear Toolbox, ArcSoft PhotoStudio, MP Navigator EX
29.2 cm
40.9 cm
4.4 cm
2.1 kg
5 °C
35 °C
10 - 90%
Customer reviews
Write a review for the Canon CanoScan LiDE 700F here!
Canon Lide 700F
Reviewed by Jonathan. Review Posted 02/10/2009
Excellent product and good value. I bought it to replace an ageing HP Scanjet which never fully functioned with XP. This is simplicity to install and does away with the need for a separate power supply. Mainly used for copying and creating pdf's in small business. Really useful is that it remembers lightness & darkness settings as I need to pick up faint details copying
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
