BT.com
Wishlist
Canon CanoScan LiDE 700F
Delivery
Standard Due date unavailable
With its ingenious 3-way design and 180° lid, the LiDE 700F brings high resolution scanning to work spaces of all sizes. For exceptional detail and enlargements, scan 35mm film at up to 9600dpi.
A LiDE scanner with CIS sensor provides a winning combination of incredibly high resolution scans and low energy consumption. Powered by a single USB cable, connected to a computer, the LiDE 700F has no need for an additional power cable, making it truly portable and space saving.
Incredibly high resolution scans from 35mm film are possible thanks to a dedicated clip-on film scanning unit. This means massive enlargements and intricately detailed prints can be achieved from your 35mm film negatives/positives.
Canon CanoScan LiDE 700F - flatbed scanner
Flatbed scanner - desktop
Interface Type
USB 2.0
Scan Element Type
Contact Image Sensor (CIS)
Light Source
RGB LED array
Max Supported Document Size
216 x 297 mm
Input Type
Grayscale / Color Depth
48-bit colour
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 48-bit colour
Optical Resolution
9600 dpi x 9600 dpi
Interpolated Resolution
19200 dpi x 19200 dpi
Scan Speed
2.4 ms / line (colour)
Max Document Size
216 mm x 297 mm
Supported Document Type
Plain paper, film
Microsoft Windows 2000 Professional, Microsoft Windows XP, Apple MacOS X 10.4, Apple MacOS X 10.3.9, Microsoft Windows Vista, Apple MacOS X 10.5
Microsoft Certification
Certified for Windows Vista
29.2 cm x 40.9 cm x 4.4 cm
2.1 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
216 x 297 mm
Scanner
Input Type
Grayscale Depth (External)
Colour Depth
48-bit colour
Colour Depth (External)
48-bit colour
Optical Resolution
9600 dpi x 9600 dpi
Scan Element Type
Bulb / Light Source Type
RGB LED array
Scan Speed
Scanner Speed Details
2.4 ms/line - colour - 300 dpi , 2.3 ms/line - black & white - 300 dpi , 33.5 ms/line - colour - 4800 dpi , 11.3 ms/line - black & white - 4800 dpi , 2.3 ms/line - greyscale - 300 dpi , 11.3 ms/line - greyscale - 4800 dpi
Scanner Features
Powered by USB port
Media Handling
Max Document Size
216 mm x 297 mm
Plain paper, film
USB 2.0 - Type B
Film adaptor
1 x USB cable
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
Power Consumption Operational (Standby)
2.5 Watt ( 1.5 Watt )
Software Included
Drivers & Utilities, ScanGear Toolbox, ArcSoft PhotoStudio, MP Navigator EX
29.2 cm
40.9 cm
4.4 cm
2.1 kg
5 °C
35 °C
10 - 90%
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Canon Lide 700F
Reviewed by Jonathan on 02/10/2009
Excellent product and good value. I bought it to replace an ageing HP Scanjet which never fully functioned with XP. This is simplicity to install and does away with the need for a separate power supply. Mainly used for copying and creating pdf's in small business. Really useful is that it remembers lightness & darkness settings as I need to pick up faint details copying
Scroll to top
