BT.com
Wishlist
Cables Direct VGA Cable HD-15 (M) to HD-15 (M) - 10m - Moulded, Thumbscrews - Black
Cables Direct VGA Cable HD-15 (M)...
£8.22
More than 50 in stock
£8.22
Add to wishlist
Delivery
Standard 3-5 working days
Our range on Super VGA cables are constructed using UL2919 approved 28awg triple mini coaxial and 4x 28awg conductor cables, this allows them to be used for extended distances. Triple shielded with copper braid, foil and drain wire. Our cables are designed for standard monitors and widescreen LCD’s that require DDC cable.
Cables Direct VGA cable - 10 m
VGA cable
Triple shielded
Molded, thumbscrews, drain wire
Length
10 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - male
UL 2919, DDC
1 year warranty
VGA cable
Triple shielded
Shielding Material
Foil with copper braid
American Wire Gauge (AWG)
28
Length
10 m
Connector
UL 2919, DDC
1 year warranty
Scroll to top
