BT.com
Wishlist
Cables Direct Leaded USB Type-C to 3 Port USB Hub & Card Reader
Cables Direct Leaded USB Type-C to...
£17.68
39 in stock
£17.68
Add to wishlist
Delivery
Standard 3-5 working days
The USB3C-HUB3CR is a USB-C to three USB 3.0 hub with a Micro SD and SD/MMC port. The USB 3.0 port allows you to connect a USB device or another hub to the host USB-C computer, the Micro SD and SD/MMC port allows you to access memory cards on the host PC. It can work with Macbook’s or Google’s Chromebook Pixel as well as other USB-C supported devices.
Cables Direct USB3C-HUB3CR - hub - 3 ports - desktop
Hub - 3 ports
Enclosure Type
Desktop
Subtype
USB
Ports
3 x SuperSpeed USB 3.0
USB 2.0, USB 3.0
1 year warranty
Bundled Services
1 year warranty
Hub - 3 ports
Enclosure Type
Desktop
Subtype
USB
Ports
USB 2.0, USB 3.0
Built-in Devices
microSD card reader, SDXC card reader
3 x USB 3.0 - Type A , 1 x USB-C - Type C - uplink
1 x USB-C cable - 15 cm
Limited warranty - 1 year
Scroll to top
