BT.com
Wishlist
Cables Direct Leaded USB Type C to 2 Port USB Hub & Card Reader
Cables Direct Leaded USB Type C to...
£22.86
£22.86
Add to wishlist
Delivery
Standard Due date unavailable
The USB3C-HUB2CR-WPD is a USB-C to two port USB 3.0 hub with USB-C charging port and Micro SD and SD/MMC port. The USB 3.0 port allows you to connect a USB device or another hub to the host USB-C computer, the USB-C female port can charge the host computer, the Micro SD and SD/MMC port allows you to access memory cards on the host PC. It can work on Macbook’s or Google’s Chromebook Pixel as well as other USB-C supported devices.
Note: The Micro SD and SD/MMC port won’t work simultaneously, you can choose to use one of them according to your practical needs.
Cables Direct USB3C-HUB2CR-WPD - hub - 2 ports - desktop
Hub - 2 ports
Enclosure Type
Desktop
Subtype
USB
Ports
2 x SuperSpeed USB 3.0
USB 2.0, USB 3.0
1 year warranty
Bundled Services
1 year warranty
Hub - 2 ports
Enclosure Type
Desktop
Subtype
USB
Ports
USB 2.0, USB 3.0
Built-in Devices
microSD card reader, SDXC card reader
2 x USB 3.0 - Type A , 1 x USB-C (power only) - Type C , 1 x USB-C - Type C - uplink
1 x USB-C cable - 15 cm
Limited warranty - 1 year
Scroll to top
