Click to visit BT.com
BT.com
Wishlist
C2G TRULink® USB Infrared PC Media Remote
£21.93
Control your PC/Media Center with an easy to use remote
Control your PC/Media Center from across the room with this sleek and easy to use TruLink PC Remote. The Infrared (IR) signal from the remote can be picked up by the sensor from up to 6 meters away, providing flexibility & convenience in equipment placement. The sensor is connected to your Computer via USB 2.0 connection. Using this remote you can power you TV and Media Center through on screen menus that are specially designed for remote control interaction.
  • USB 2.0 Certified
  • Infrared Signal extends up to 6 meters
  • Sleek and Slim Remote to control both TV and Media Center
  • No software required
  • Free technical support & 1yr warranty
  • Pentium 4 or higher processor.
  • Microsoft Windows® XP with MCE, Vista Home Premium and Vista Ultimate operating system.
  • Microsoft Internet Explorer 6.0 or later.
Package Contents
  • (1) Infrared Sensor
  • (1) Remote control
  • (1) User manual
  • (1) Two Pack Batteries for remote .
C2G TRULink® USB Infrared PC Media Remote Bundle deal on C2G TRULink® USB Infrared PC Media Remote
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £14.98 | while stocks last
£31.92
saving £4.99
Including:
Intenso 32GB Rainbow Transparent USB Flash Drive Intenso 32GB Rainbow Transparent USB Flash Drive worth £4.98 | in stock
£26.02
saving £0.88
Type: Remote Control
Brand: C2G
Price Range Inc VAT: 0 - 50
