BT.com
Wishlist
C2G Swiss 250 Volt 16 Amp Power Cord
Delivery
Standard Due date unavailable
Make your work environment more flexible and efficient. This heavy duty 1.5mm² cord is designed to work with PDUs, PSUs and other high power devices that use the 3-pin male-to-female shroud power connector. Plus it features a fully moulded design for maximum durability and long life. The female connector plugs directly into the device while the male connector plugs into another power cord, or auxiliary power port on power supply for auto power when the system is turned on.
C2G Swiss 250 Volt 16 Amp Power Cord - power cable - 2 m
Power cable
Molded
Length
2 m
Switzerland
Connector
1 x power IEC 60320 C19 16A - male
Connector (Second End)
1 x power SEV 1011 - male
Rated Voltage
AC 250 V
Power cable
Rated Voltage
AC 250 V
Molded
Length
2 m
Switzerland
Connector
RoHS, Directive 2011/65/EU
Scroll to top
