BT.com
Wishlist
C2G HDBaseT HDMI + USB Over Cat5 Extender Video/Audio/Infrared/USB/Serial Extender HDBaseT 2.0
C2G HDBaseT HDMI + USB Over Cat5...
£775.29
£775.29
Add to wishlist
Delivery
Standard Due date unavailable
His HDBaseT HDMI + USB over cat5 extender is an ideal solution to deliver audio, video and USB signals from a computer or media player to an interactive whiteboard, touch screen, digital signage, or other interactive displays. Simply connect with an audience.
Target customers with an interactive 4K touchscreen display or engage students with an interactive whiteboard. This powerful system offers USB control of interactive displays while delivering 4K video and all major digital audio formats through HDMI, providing a dynamic experience and truly connecting with any audience. Going the distance.
Connecting with an audience is one thing, but delivering the content and control from a distance is more complex. This Kit removes the complexity of transmitting both A/V content and USB control to touch screens or from conference camera systems. This straightforward solution allows the content and control to be delivered up to 100 meters uncompressed, which enables installation options far beyond the length limitations of standard USB or HDMI cabling. Remote operation.
The HDBaseT HDMI + USB over Cat5 extender functions as an interface point for remote terminals, which provides a single simple solution to control remote devices . With 4K HDMI audio/video output and 4 USB ports this kit allows for USB devices like a touch screen, conference camera, mouse, or keyboard next to an HDMI display to be installed in a remote location. This setup provides remote control and access of a computer or other source device installed in a secure location. Straightforward install and setup.
Save time and money with an effortless install. Simply run two solid conductor Cat5e or Cat6 cables up to 100 meters (328 feet) between the transmitter at the source and the receiver at the display, connect all applicable devices, connect the power adapter and turn power on for all devices. There are no drivers to install. This plug and play solution passes EDID and HDCP, and supports all USB 2.0 functionality ensuring quick install and a setup with no configuration. Extended control.
This HDBaseT HDMI+ USB over Cat5 extender system also extends IR and Serial control up to 100 meters (328 feet). Control peripheral devices like a 4K display, projector, Blu-ray player or other IR or serial controlled devices using a standard remote or a serial terminal.
C2G HDBaseT HDMI + USB Over Cat5 Extender - video/audio/infrared/USB/serial extender - HDBaseT 2.0
Video/audio/infrared/USB/serial extender
Desktop
HDBaseT 2.0
Max Transfer Distance
100 m
AC 120/230 V
9.8 cm x 10.2 cm x 2.8 cm
1.6 kg
3 years warranty
Desktop
Wired
HDBaseT 2.0
100 m
Status Indicators
Status
Firmware upgradable, wall mountable, 4K resolution support, EDID Pass-Through, Dolby TrueHD support, DTS-HD Master Audio support, DTS support
USB 1.1, USB 2.0, HDCP 2.2
1 x HDMI (input) - 19 pin HDMI Type A female , 1 x HDMI (output) - 19 pin HDMI Type A female , 1 x TOSLINK (input) female , 1 x TOSLINK (output) female , 1 x RS-232 (input) - RJ-11 female , 1 x RS-232 (output) - RJ-11 female , 1 x audio (input) - mini jack female , 1 x audio (output) - mini jack female , 2 x IrDA (input) female , 2 x IrDA (output) female , 1 x mini-USB (power) - Type B female , 4 x USB 2.0 - Type A female
IR extender, IR receiver, foot pad set
1 x mini-USB to USB cable , 2 x DB-9 to RJ-11 adapter , Serial cable , RJ-11 phone cable
Mounting Kit
Included
VCCI, FCC, RoHS2
External power adapter
AC 120/230 V (50 - 60 Hz)
9.8 cm
10.2 cm
2.8 cm
1.6 kg
Limited warranty - 3 years
0 - 80% (non-condensing)
Scroll to top
