BT.com
Wishlist
C2G CablesToGo 5m 1394 FW ACTIVE REPEATER CBL
Delivery
Standard Due date unavailable
Overcome the usual 4.5-meter length limitation of the IEEE-1394 standard. With this active extension cable, you can now extend your current cable another 5 meters! This is ideal for any situation where your device needs to be placed some distance from your computer. Compatible with 1394-1994 standards, this cable is fully interoperable with the FireWire standard.
Data transfer rates up to 400 Mbps are supported and you can daisy-chain up to 5 active extension cables to extend the distance of your cable an additional 25 meters! It is Plug-and-play and hot-swappable.
C2G 5m 1394A Active FireWire Extension Cable - IEEE 1394 (FireWire) extender - Firewire
External
Data Transfer Rate
400 Mbps
Firewire
Max Transfer Distance
5 m
External
Wired
Firewire
Data Transfer Rate
400 Mbps
5 m
1 x FireWire - 6 pin female
RoHS
Scroll to top
