BT.com
Wishlist
C2G 7m LC-SC 9/125 OS1 Duplex Singlemode PVC Fibre Optic Cable (LSZH) - Yellow
C2G 7m LC-SC 9/125 OS1 Duplex...
£22.66
5 in stock
£22.66
Add to wishlist
Delivery
Standard 3-5 working days
Cost-effective solution that provides high bandwidth and transmission rates over longer distances. With LC to SC termination, this high quality fibre optic patch cable is specifically designed for Gigabit Ethernet applications. The Low Smoke Zero Halogen (LSZH / LS0H) jacket is composed from materials that lessen the smoke and halogen emissions when the cable is exposed to extreme temperatures. This reduces the amount of harmful toxic and corrosive gases that cabling made with plastic materials would otherwise emit into the air during combustion. This construction makes LSZH cables ideal for use where the protection of people and equipment from harmful corrosive gases is absolutely critical. The patented injection moulding process provides each connection greater durability in resisting pulls, strains and impacts from cabling installs. Each cable is 100% optically inspected and tested for insertion loss before you receive it. A pull-proof jacket design surrounds the popular 9/125 Single-mode fibre, immune to electrical interference.
C2G LC-SC 9/125 OS1 Duplex Singlemode PVC Fiber Optic Cable (LSZH) - patch cable - 7 m - yellow
Patch cable - OS1
Fibre optic
Type of Fibre Optics
Singlemode
Halogen-free
Length
7 m
Core / Cladding Diameter
9 / 125 micron
Connector
2 x SC single-mode - male
Connector (Second End)
2 x LC single-mode - male
Yellow
Network Cable Type
Patch cable - OS1
Fibre optic
Singlemode
Jacket Material
Low Smoke Zero Halogen (LSZH)
Fibre Qty
2
9 / 125 micron
Halogen-free
Length
7 m
Yellow
Connector
TIA/EIA-455-171A
-20 °C
70 °C
Scroll to top
