BT.com
Wishlist
C2G 7m DB9 M/F Extension Cable - Beige
Delivery
Standard Due date unavailable
Don't sacrifice convenience when determining where to place your hardware. A DB9 extension cable can give you the flexibility to extend a computer peripheral wherever you need it. Each extension cable comes fully shielded to prevent unwanted EMI/RFI interference, and the fully snagless cable design delivers excellent strain relief. Connector thumbscrews provide a quick and easy connection every time. All lines are wired straight through.
C2G serial extension cable - 7 m
Serial extension cable
Shielded
Molded, thumbscrews
Length
7 m
Connector
9 pin D-Sub (DB-9) - female
Connector (Second End)
9 pin D-Sub (DB-9) - male
Beige
Shielded
Molded, thumbscrews
Length
7 m
Beige
Connector
RoHS
Scroll to top
