The Pro Series UXGA monitor cable with 3.5mm audio from C2G is the ideal high performance solution for quickly connecting your PC to a video display system with speakers. Use this cable with projectors, flat-screen monitors, KVM switches with audio, speakers, or a microphone. Designed to support resolutions up to 1600 x 1200, this cable can support long distances without conditioning the signal. It is ideal for video presentations, projector applications and classroom environments.
