BT.com
Wishlist
C2G 21mm 8.5in Mac®-Compatible Mini DisplayPort™ Male to DVI-D™ Female Adapter Cable
Delivery
Standard Due date unavailable
This adapter cable converts a Mini DisplayPort signal for viewing on a DVI-equipped display. Connect the adapter cable directly to the computer. Then use your DVI cable between the adapter and the display, and enjoy computer video content on virtually any high-definition digital audio/video display. Supports full HD resolution (1080p @ 60 Hz).
C2G DisplayPort adapter - 21.6 cm
DisplayPort adapter
Length
21.6 cm
Connector
Mini DisplayPort - male
Connector (Second End)
DVI-D - female
White
DisplayPort adapter
Length
21.6 cm
White
Connector
24+1 pin digital DVI - female
Scroll to top
