BT.com
Wishlist
Buffalo WZR-600DHP2-EU Wireless N600 Gigabit Dual Band Router
Delivery
Standard 1-3 working days
Buffalo's new AirStation™ Dual Band Gigabit router (WZR-600DHP2-EU) brings a new solution to Buffalo's family of wireless routers.
Upgrade your existing wireless connection with Buffalo's WZR-600DHP2-EU: a simple dual band solution with advanced features.
The WZR-600DHP2-EU provides simultaneous transfer speeds of up to 300MBps in both the 5GHz and 2.4GHz bandwidths; and managing two networks at the same time splits the workload for noticeably better performance. Perfect for streaming HD movies, music and emailing from multiple devices at the same time.
Gigabit Speed
With four gigabit LAN ports and one gigabit WAN the WZR-600DHP2-EU offer ultra-fast wired connections.
Easy, secure setup
The Buffalo AirStation™ One-Touch Secure System (AOSS™), Wi-Fi Protected Setup (WPS) and the new intuitive interface provide a quick and easy way to create a secure wireless connection to a host within minutes.
Easy file sharing
The WZR-600DHP2-EU also comes with USB 2.0 port, media server, device server, and BitTorrent™ for easy file sharing across connected devices.
Including Norton ConnectSafe
The AirStation™ Dual Band Gigabit router also offers Norton ConnectSafe™ that defends your network and family against unsafe or undesirable websites. It's a basic security that blocks access to problem sites and automatically protects your device against phishing and malware sites. Content from 30 categories is blocked while you keep the ability to always allow certain sites or make exceptions for single clients.
BUFFALO AirStation WZR-600DHP2 - wireless router - 802.11a/b/g/n - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
300 Mbps
NAT support, auto-uplink (auto MDI/MDI-X), packet filtering, Intrusion Detection System (IDS), MAC address filtering, VPN passthrough, parental control, Airstation OneTouch Secure System (AOSS), MIMO technology, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), BitTorrent Client, Stateful Packet Inspection Firewall (SPIF), Direct Sequence Spread Spectrum (DSSS)
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n
2.8 cm x 18.5 cm x 20 cm
520 g
Microsoft Windows XP, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Apple MacOS X 10.4 - 10.8
3 years warranty
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
300 Mbps
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, TKIP, WPA, WPA2, WPA-PSK, WPA2-PSK
Line Properties
Line Coding Format
OFDM
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A
Aerial
Aerial
Internal
Antenna Qty
4
External power adapter
23 Watt
Mounting Kit
Included
Software Included
Norton ConnectSafe
2.8 cm
18.5 cm
20 cm
520 g
Limited warranty - 3 years
10 - 85% (non-condensing)
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.62
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.08
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£19.50
£13.60
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£30.90
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£17.86
Scroll to top
