BT.com
Wishlist
Buffalo Wireless 11ac 1166 Gigabit Dual Band Router with Parental Control
Delivery
Standard Due date unavailable
Buffalo's new AirStation Dual Band 11ac Wireless Gigabit router (WZR-1166DHP-EU) brings a new and versatile dual band solution with fast transfer speeds and beamforming technology. The WZR-1166DHP-EU is primed and ready-to-go with transfer speeds of up to 866 MBps in the 5GHz spectrum and 300Mbps on the 2.4GHz bandwidth. The 5GHz band is ideal for faster, uninterrupted HD video streaming and concurrent Internet access for new mobile phones, tablets, and laptops. And your other devices will also benefit from the new simultaneous fast transfer speeds in the 2.4GHz bandwidth.
Buffalo's new AirStation uses beamforming technologies to remarkably improve your wireless connection. Beamforming recognizes the devices using wireless and focuses the signal directly to them. And once focused, your wireless signal will have better ability to reach around corners and through walls, helping to eliminate or reduce previous performance obstacles.
In addition to all of this, the AirStation Dual Band 11ac Wireless Gigabit router comes with parental control by Symantec. Upgrade your existing wireless connection to provide greater coverage, beamforming, fast transfer speeds - all whilst protecting your family, Buffalo's new AirStation is the next generation of wireless connectivity.
BUFFALO AirStation WZR-1166DHP - wireless router - 802.11a/b/g/n/ac - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
866 Mbps
NAT support, auto-uplink (auto MDI/MDI-X), packet filtering, Intrusion Detection System (IDS), print server, MAC address filtering, VPN passthrough, parental control, Airstation OneTouch Secure System (AOSS), MIMO technology, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), port forwarding, Stateful Packet Inspection Firewall (SPIF), Direct Sequence Spread Spectrum (DSSS)
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.11ac
3.4 cm x 18.3 cm x 21.2 cm
593 g
Microsoft Windows XP, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Apple MacOS X 10.4 - 10.8
3 years warranty
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
866 Mbps
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, TKIP, WPA-PSK, WPA2-PSK
Authentication Method
Radio Service Set ID (SSID)
Line Properties
Line Coding Format
CCK, OFDM
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 1 x 9 pin USB Type A
Aerial
Aerial
Internal
Antenna Qty
4
External power adapter
15.1 Watt
3.4 cm
18.3 cm
21.2 cm
593 g
Limited warranty - 3 years
20 - 80% (non-condensing)
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.62
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.08
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£19.50
£13.60
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£30.90
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£17.86
Scroll to top
