BT.com
Wishlist
Buffalo Wireless 11ac 1166 Gigabit Dual Band Router
Delivery
Standard Due date unavailable
The new Buffalo AirStation Wireless Router (WHR-1166D-EU) is ready for the latest 11ac smartphones, tablets, or laptops and designed especially for users focused on their wireless connections.
The WHR-1166D provides up to 866 Mbps transfer speed in the 5GHz band and simultaneous transfer speeds of up to 300 Mbps in the 2.4GHz band. Furthermore, easy setup is a few clicks away via a simple User Interface that's accessible on a computer, smartphone, or tablet. Buffalo's new AirStation is also very family-friendly with Norton ConnectSafe web filtering as well as Parental Control that allows you to limit the amount of time specific users are connected.
And for more advanced users the WHR-1166D also has functionalities like QoS, port forwarding and guest port. The guest port feature allows you to both share your internet connection with visitors and also isolate your own network devices - keeping you, and your guests, entirely separate. Buffalo's new AirStation can also be integrated into an existing network as a wireless range extender for even better and further reach.
Dual band 11ac with great wireless performance and security, Buffalo's new AirStation WHR-1166D-EU is a smart choice for homes and small office networks looking to upgrade their network with a fast 11ac wireless router.
LAN Ports - 4x100mbps RJ45 Auto MDIX
WAN Ports - 1x Gigabit RJ45 Auto MDIX
BUFFALO AirStation WHR-1166D - wireless router - 802.11 a/b/g/n/ac - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Data Transfer Rate
1166 Mbps
Network / Transport Protocol
PPTP
NAT support, auto-uplink (auto MDI/MDI-X), packet filtering, Intrusion Detection System (IDS), MAC address filtering, parental control, Airstation OneTouch Secure System (AOSS), MIMO technology, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), hidden SSID, Buffalo High Power technology, port forwarding, Stateful Packet Inspection Firewall (SPIF), Direct Sequence Spread Spectrum (DSSS), VPN Server
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
AC 120/230 V ( 50/60 Hz )
5.5 cm x 13 cm x 15.9 cm
280 g
Microsoft Windows XP, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Apple MacOS X 10.5 - 10.9
3 years warranty
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz, 5 GHz
Data Transfer Rate
1166 Mbps
PPTP
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, TKIP, WPA-PSK, WPA2-PSK
Authentication Method
Radio Service Set ID (SSID)
Line Properties
Line Coding Format
CCK, OFDM
LAN : 4 x 10Base-T/100Base-TX - RJ-45 ¦ WAN : 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
External power adapter
10.8 Watt
Vertical stand
Software Included
Norton ConnectSafe
5.5 cm
13 cm
15.9 cm
280 g
3 years warranty
Service & Support Details
Limited warranty - 3 years
10 - 85% (non-condensing)
Accessories
£4.95
£3.84
£11.67
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.42
£52.93
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
4* Gigabit - not so much!!
Reviewed by Robert on 19/01/2015
This is a good value Wifi-AP if you have an existing modem. I wanted something with 5Ghz - this delivers in spades. I can disable 2.4Ghz WiFi and do quad channel bonding on 5Ghz. Indoors the range and speed appears to be good for 5Ghz (Nexus 7 & Oneplus One - used through multiple internal walls).
The WebUI is loaded up with features. You can:
schedule the device to turn off or sleep on a full 7-day hour by hour schedule (nice!!)
you can change the MTU
you can enable or disable the inbuilt DHCP Server (including allowing IP passthrough from an existing Router/DHCP Server)
you can enable or disable UPnP
you can enable or disable both the 2.4Ghz and 5.0Ghz access
you can set separate SSID names for 2.4Ghz & 5.0Ghz
However a have to ding the device a star... The only port that is Gbit is the main WAN patch port. If you're doing IP/DHCP pass-through you have to use one of the 4x 100Mbit LAN patch ports.
The only port that doesn't need to be Gbit - in any usage scenario is the WAN port!!
Scroll to top
