BT.com
Wishlist
Buffalo WI-U2-300D-EU Wireless 11n300 USB2.0 Adapter
Delivery
Standard Due date unavailable
Compact and Versatile Dual-Band Wireless Networking
Buffalo Technology's new Airstation™ Wireless N300 Dual Band USB Adapter (WI-U2-300D-EU) is a quick and easy way to make your computer compatible with new dual band high speed routers.
Users will be impressed by the speed and ease of the new Airstation™ adapter which is compatible with both the 2.4GHz and 5GHz bandwidths for maximum versatility.
The 5GHz bandwidth is much less crowded and therefore ideal for faster, uninterrupted HD video streaming and concurrent Internet access. And depending on your network conditions, there are also advantages, to utilising the 2.4GHz spectrum such as further range.
Be impressed by the speed and ease of the new Airstation™ adapter which is compatible with both the 2.4GHz and 5GHz bandwidths for maximum versatility. The 5GHz bandwidth is much less crowded and therefore ideal for faster, uninterrupted HD video streaming and concurrent Internet access.
High-speed streaming
Buffalo's new adapter makes fast data transfers, demanding applications, gaming, streaming video, and anything else, available in every corner of your home or office on almost any computer with an available USB port.
Easy, secure setup
Push-button wireless setup with the Buffalo AirStation™ One-Touch Secure System (AOSS™) and Wi-Fi Protected Setup (WPS)
Upgrade non-dual band computers
Fast and stable connections, a compact design that doesn't get in way, plus a clipping extension cable for optimal placement: Buffalo's new adapter is the easy way to upgrade non-dual band computers!
BUFFALO AirStation WI-U2-300D - network adapter
Network adapter
External
Interface (Bus) Type
USB 2.0
7.4 cm x 1.4 cm x 2.7 cm
18 g
802.11b, 802.11a, 802.11g, 802.11n
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz, 5 GHz
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, USB 2.0, IEEE 802.11n
Microsoft Windows XP SP3, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits)
3 years warranty
Network adapter
External
USB 2.0
Wireless
Spread Spectrum Method
OFDM, DSSS
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz, 5 GHz
Airstation OneTouch Secure System (AOSS), USB powered, MIMO technology, Wi-Fi Protected Setup (WPS)
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, TKIP, WPA-PSK, WPA2-PSK
2.5 Watt
Software Included
Drivers & Utilities
7.4 cm
1.4 cm
2.7 cm
18 g
Limited warranty - 3 years
10 - 85% (non-condensing)
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.72
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.26
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£21.20
£14.65
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£30.90
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£18.55
Scroll to top
