BT.com
Wishlist
Buffalo Business Switch L2 10 Gigabit 12 Port
Delivery
Standard Due date unavailable
Buffalo's BS-XP series of 10GbE switches offers an easy, cost-effective and energy-efficient way to extend your business network at blazing speeds. Plug and play installation requires no additional software or configuration; simply plug your network-ready devices into one of the available Ethernet ports. Each AUTO-MDIX port automatically detects and configures the correct connection while optional jumbo frame support and full duplex operation provide maximum performance.
Along with 802.3az Green Ethernet technology, the BS-XP series includes intelligent Power Control, an energy conservation feature that monitors the activity status of each port to reduce the total power consumed. Its durable, metal chassis is equipped with holes for wall-mounting or rubber feet for easy placement on a desktop.
With 10GbE speeds, eco-minded operation, performance-minded features and a lifetime warranty, Buffalo's BS-XP series of switches is a perfect network extension for your business.
What's in the box
  • BUFFALO BS-XP Series BS-XP2012
  • Rubber feet
  • Rack mounting kit
BUFFALO BS-XP Series BS-XP2012 - switch - 12 ports - rack-mountable
Switch - 12 ports
Enclosure Type
Rack-mountable
Subtype
10 Gigabit Ethernet
Ports
12 x 10 Gigabit Ethernet
Performance
Latency: 10 ms , Data transfer rate: 120 Gbps
Jumbo frame size: up to 9 KB , MAC addresses: 16000 , Buffer capacity (MB): 2
MAC Address Table Size
16000 entries
Jumbo Frame Support
9216 bytes
VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, store and forward, Quality of Service (QoS), Green Ethernet, reset button, Traffic Control, loop prevention, metal housing, Link Aggregation
IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3an, IEEE 802.3az
AC 100 - 240 V (50/60 Hz)
33 cm x 23 cm x 4.4 cm
2.57 kg
Europe
3 years warranty
Switch - 12 ports
Enclosure Type
Desktop, rack-mountable, wall-mountable
Subtype
10 Gigabit Ethernet
Ports
Performance
16000 entries
Jumbo Frame Support
9216 bytes
Status Indicators
Port transmission speed, power, link/activity
12 x 10GBase-T RJ-45
Internal power supply
50 Watt
Rubber feet
Rack Mounting Kit
Included
CB, FCC, IC Class A, VCCI Class A
Europe
33 cm
23 cm
4.4 cm
2.57 kg
Limited warranty - 3 years
50 °C
10 - 85% (non-condensing)
Scroll to top
