BT.com
Wishlist
Buffalo AirStation NFINITI Wireless-N 300Mbps Modem Router
Delivery
Standard Due date unavailable
The Buffalo AirStation Nfiniti HighPower Wireless Gigabit Broadband ADSL2+ Modem Router provides up to 300Mbps performance and extended coverage and also comes with 4 Gigabit ports for maximum speed.
The HighPower technology reduces dead spots, and extends the range in and around your home or small business, to ensure good performance even in those difficult to reach places. Multiple levels of wireless and wired security are available, to keep your computer and network secure even when using lower levels of encryption for e.g. gaming consoles.
The modem router comes with a USB port that can be used to attach and share a network storage device or USB hard disk or to connect a USB multi-function printer. The USB port also supports powered USB 2.0 up to 4 port hubs.
Automatic channel support selects the best available wireless networking channel.
Built-in 4-port 10/100/1000 Auto-Sensing Switch
USB 2.0 port makes it possible to connect a printer or network storage device.
Built-in DLNA™ Media Server
Built-in media server streams multimedia content to DLNA™ clients on your network.Movie engine feature optimises media streaming.
Built-in BitTorrent ™ client*
Download rich media files independently without having to power up your PC or laptop with the built-in BitTorrent™ client feature. The BitTorrent™ client frees your PC or laptop for other activities. A BitTorrent™ client is a programme that uses the BitTorrent™ protocol to manage large file downloads and uploads over the Internet.
Remote Web Access
Access your digital content via a Web browser to a PC or Mac, or via the WebAccess I app to your iPhone®, iPad® or Android SmartPhone.
Firewall protection
Use the built-in DHCP Server to assign IP addresses to wireless clients.
Remote network access through VPN Server/Gateway
VPN feature allows you to access the network remotely over the Internet - via a VPN server or gateway.
Eco-friendly, energy-saving feature reduces consumption by up to 65%.
Limited Warranty: 3 years
BUFFALO AirStation Nfiniti WBMR-HP-G300H - wireless router - DSL modem - 802.11b/g/n - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL2+
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Firewall protection, DHCP support, VPN support, auto-uplink (auto MDI/MDI-X), Stateful Packet Inspection (SPI), DoS attack prevention, Intrusion Detection System (IDS), Airstation OneTouch Secure System (AOSS), MIMO technology, BitTorrent Client
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, DLNA CERTIFIED
AC 120/230 V ( 50/60 Hz )
16.5 cm x 15.8 cm x 3.5 cm
380 g
2 years warranty
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, TKIP, WPA-PSK, WPA2-PSK
Communications
DSL modem
ADSL2+
Protocols & Specifications
ITU G.992.1 (G.DMT) Annex A, ITU G.992.3 Annex A
Max Transfer Rate
24 Mbps
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x ADSL2+ , USB 2.0: 1 x
External power adapter
12 Watt
16.5 cm
15.8 cm
3.5 cm
380 g
20 - 80% (non-condensing)
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.81
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.50
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£22.51
£15.94
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£30.20
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£20.47
C2G USB Superbooster Extender Kit
Quicklinx: 7H7B | In Stock
£40.12
£42.26
Resources
The following resources are available for the Buffalo AirStation NFINITI Wireless-N 300Mbps Modem Router
Scroll to top
