BT.com
Wishlist
Buffalo 8x Ultra-Slim USB 2.0 Portable DVD Writer w/ Bus Powered LED
Delivery
Standard Due date unavailable
The MediaStation 8x Portable DVD Writer DVSM-PC58U2VB is an affordable, portable DVD writer with a sophisticated LED power indicator. This external DVD writer is the ideal companion for a laptop or netbook and is a high quality alternative to laptop manufacturers’ pricey options. The MediaStation 8x Portable DVD Writer includes two integrated USB cables that snap to the chassis for easy mobility. Powered by your laptop USB ports, no AC adapter is necessary. If the power from a single USB port is insufficient, the red LED will glow, indicating additional power is required. In this instance, the convenient USB Y-cable allows you to connect to a second USB port to power the unit. The MediaStation 8x Portable DVD Writer also includes CyberLink DVD software suite for Windows, letting you easily create CDs and DVDs.
BUFFALO MediaStation 8x Portable DVD Writer with LED Power Indicator - DVD±RW (±R DL) / DVD-RAM drive - USB 2.0
DVD±RW (±R DL) / DVD-RAM drive - external
USB 2.0
14.5 cm x 15.2 cm x 2 cm
340 g
Optical Storage
Read Speed
24x (CD) / 8x (DVD)
Write Speed
24x (CD) / 8x (DVD±R) / 6x (DVD±R DL)
CD / DVD Rewrite Speed
24x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM)
Media Load Type
Tray
Europe
2 years warranty
USB 2.0
14.5 cm
15.2 cm
2 cm
340 g
Europe
Optical Storage
Read Speed
24x (CD) / 8x (DVD)
Write Speed
Supported Media Types
CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RAM, DVD-RW, DVD+RW, DVD+R
Media Load Type
Tray
USB powered
1 x USB 2.0 - 4 pin USB Type A
1 x PoweredUSB cable
Software Included
Cyberlink DVD Solution
Microsoft Windows XP, Apple MacOS X 10.6, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits)
Scroll to top
