BT.com
Wishlist
Buffalo 512GB DriveStation Mini Thunderbolt Desktop Hard Drive
Select:
Delivery
Standard Due date unavailable
Dual Thunderbolt™ and Dual SSD: Harness the Full Potential of Thunderbolt™
Buffalo Technology's new SSD-WAT series DriveStation™ Mini Thunderbolt™ has two Solid State Drives (SSD), and two Thunderbolt™ ports, which together can realize the SSD-WAT's full potential to deliver fantastic speed.
Perfect for creative production environments, demanding applications, and demanding home users.
Dual SSD and dual Thunderbolt™ ports deliver amazing speed
With read speed of approximately 615 MBps, and write speed of about 760 MBps*, Buffalo's DriveStation™ Mini Thunderbolt™ is ready to face the most demanding applications, perform fast data transfers, backups, and more. In practical terms these benchmarks equate to copying 800MB (+/- 1000 photos) in 1.3 seconds.
Apple friendly
The DriveStation™ Mini Thunderbolt™ can be formatted to support both PC and Mac® making it a great portable storage solution for any device. Native Compatibility with Mac OS X Time Machine also makes it an ideal solution for backup with Mac computers.
RAID
When paired with a RAID-capable host the the SSD-WAT's dual SSD facilitate software RAID.
It's possible to set it up as a mirrored RAID set (RAID 1), which provides data protection if one disk fails. Alternatively, configure it as a striped RAID set (RAID 0) to maximize speed and capacity for large file storage and fast transfers.
Daisy-chain additional drives
The ability to daisy-chain additional drives - further increasing both speed and capacity benchmarks - make the SSDWAT series perfect for creative production environments and other professional applications as well as demanding home users.
  • Deliver Lightening Speed: Write speed approximately 760 MBps, Read speed approximately 615 MBps, Able to copy 800MB (+/- 1000 photos) in 1.3 seconds
  • RAID: When paired with a RAID-capable host the SSD-WAT facilitates software RAID
  • Daisy Chain: Ready to daisy chain up to 6 devices to further increase speed and capacity
  • Thunderbolt™ Technology: Thunderbolt™ technology dramatically increases transfer performance with bi-directional 10 Gbps speed, and offers daisy chaining to multiple devices.
  • Apple friendly: Ready for use for Mac immediately and Works for Mac TimeMachine (HFS+ formatted).
  • HDD Type2.5 SSD
  • HDD InterfaceSATA III 6Gb/s
  • Total Capacity 512GB
  • Number of Drives2
  • Supported RAID LevelsControlled by host
  • Interface(s): Standard ComplianceThunderbolt™
  • Connector TypeThunderbolt™ (Mini DisplayPort)
  • Number of Ports2
  • Data Transfer Rate10Gb/s duplex (uplink and downlink)
  • OS SupportMac OS X 10.6 or later, Windows 8 (64/32-bit), Windows® 7 (64/32-bit)
  • Dimensions (WxDxH)45x102x154 mm
  • Weight540g
  • Operating Environment5-35°C, 20-80% (non-condensing)
  • Power Consumption24W or 48W in daisy chain
  • Power SupplyExternal AC 100-240V 50/60 Hz
BUFFALO DriveStation Mini Thunderbolt - hard drive array
Hard drive array
Total Array Capacity
512 GB
Thunderbolt
2 (installed) / 2 (max)
Supported Drives
SATA-600
Storage Controller
RAID (SATA 6Gb/s) - RAID 0, 1
Hard Drive
2 x 256 GB HDD SATA 6Gb/s Apple Time Machine compatible, HFS+ formatted
Apple MacOS X 10.6 or later, Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits)
AC 120/230 V - 50/60 Hz
4.5 cm x 10.2 cm x 15.4 cm
540 g
Hard drive array
Chassis
2
Supported Devices / Modules Qty
2
Supported Drives
SATA-600
Storage
512 GB
HDD Array External Interface
Thunderbolt
Storage Controller
RAID - integrated
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1
Hard Drive
HDD
2 x 256 GB
Interface Type
SATA 6Gb/s
Expansion Bays
2 (total) / 0 (free) x internal
2 x Thunderbolt - Mini DisplayPort
External power adapter
24 Watt
4.5 cm
10.2 cm
15.4 cm
540 g
5 °C
35 °C
20 - 80% (non-condensing)
Resources
The following resources are available for the Buffalo 512GB DriveStation Mini Thunderbolt Desktop Hard Drive
Scroll to top
