BT.com
Wishlist
Buffalo 500GB MiniStation Slim (8.8mm) USB 3.0 Portable HDD Silver
Delivery
Standard Due date unavailable
500GB Capacity: Measuring a Mere 8.8 mm Thick
Buffalo Technology's new MiniStation™ Slim portable Hard Drive brings you the Buffalo quality you know and trust in a remarkably small and attractive aluminum package.
And, in addition to its good looks, users will be impressed with the MiniStation Slim's high speed data transfer via USB3.0.
  • 500GB capacity in a small case measuring just 8.8 (H) x 79 (W) x 115 (L) mm
  • Compact and Lightweight: Even slimmer than previous versions, lightweight metal chassis saves space for ultimate portability with a stylish and sophisticated design. Available in Silver, Black or Red.
  • High Speed: Native USB 3.0 and USB 2.0 compatible: Support for legacy USB 2.0 and SuperSpeed 3.0
  • Buffalo Tools: Comes with Buffalo Tools such as eco manager and Secure Lock Mobile ( for Windows) and Buffalo's Backup Utility that automatically backs up your Windows PC, protecting your data
  • Time Machine® Compatible: Works perfectly with Time Machine to back up your Mac (requires reformatting by Mac computer)
  • HDD InterfaceSATA
  • Capacities500 GB
  • Number of Drives1
  • Standard ComplianceUSB 3.0
  • Connector TypeMicro-B
  • Number of Ports1
  • Data Transfer Rate5Gbps
  • Dimensions (WxHxD)79 x 8.8 x 115 mm
  • Weight140 g
  • OS SupportWin 8 (64-bit/32-bit), 7 (64-bit/32-bit), Vista (64-bit/32-bit), XP (32-bit), Mac OS X 10.5 or later
  • Operating Environment5-35°C, 20-80% (non-condensing)
  • Power supplyUSB bus powered
BUFFALO MiniStation Slim - hard drive - 500 GB - USB 3.0
Hard drive - external ( portable )
500 GB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Bus Powered by USB, aluminium enclosure
Power Source
USB bus
Enclosure Colour
Silver
79 mm x 115 mm x 8.8 mm
140 g
2 years warranty
500 GB
USB 3.0
Internal Drive Interface
Serial ATA
79 mm
115 mm
8.8 mm
140 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0 - 10 pin Micro-USB Type B
Power Source
USB bus
Software Included
Buffalo Tools
Microsoft Windows XP, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Apple MacOS X 10.5 - 10.8
Enclosure Colour
Silver
2 years warranty
Service & Support Details
5 °C
35 °C
20 - 80% (non-condensing)
Scroll to top
