Click to visit BT.com
BT.com
Wishlist
Buffalo 500GB MiniStation Plus 2.5" USB 3.0 Red Shock Proof
Quicklinx: 7Y62WS00
Mfr#: HD-PNT500U3R-EU
MiniStation Plus offers high performance USB 3.0 portable storage in a compact and lightweight shock proof chassis. With USB 3.0 support and backward compatibility with USB 2.0, it works with any PC or Mac, providing interface speeds up to 5 Gbps. MiniStation Plus occupies minimal space and it's USB powered so there are no additional cables to manage and no need for a separate power source; simply plug it into any available USB port on your computer and instantly add capacity or store files to take on the road. With available 256-bit AES hardware encryption, you can easily protect your data from unwanted access by simply assigning a password. Store, back up and transport your content with SuperSpeed plug and play connectivity.
BUFFALO MiniStation Plus - hard drive - 500 GB - USB 3.0
Hard drive - external ( portable )
500 GB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Power Source
USB bus
Enclosure Colour
Red
8.2 cm x 1.6 cm x 11.8 cm
175 g
Europe
2 years warranty
500 GB
USB 3.0
8.2 cm
1.6 cm
11.8 cm
175 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0 - 10 pin Micro-USB Type B
Power Source
USB bus
Power Consumption
2.7 Watt ( active )
Software Included
Buffalo Tools
Microsoft Windows XP, Apple MacOS X 10.4 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits)
Enclosure Colour
Red
Europe
2 years warranty
Service & Support Details
