BT.com
Wishlist
Buffalo 500GB MiniStation Air USB 3.0 Mobile Wireless Storage
Delivery
Standard Due date unavailable
Buffalo MiniStation Air - Wi-Fi & USB 3.0 Portable HDD: Wireless streaming storage
Buffalo's MiniStation™ Air brings you the solution for the limited storage capacity on Smart Phones and Tablets. The MiniStation™ Air makes it possible to wirelessly read and even write files on smart phones and tablets. Upload your data such as photos and video on the portable Ministation™ Air while on the move. For transferring large amounts of data from desktop PC's or Laptops you can use the fast USB3.0 interface (up to 5Gb/s). The amount of data is no longer a problem, wherever you go it's always available. It's even possible to stream media to three WiFi enabled devices at the same time. This allows you to share files to streaming clients.
Thanks to the integrated WiFi, superspeed USB (USB3.0) and acapacity of 500GB you have all your data with you, wherever you go. The battery is easily charged with AC adapter or via USB on the PC and has up to 4 hours battery life.
The WiFi setup connection is easily done with WPS or AOSS. MiniStation™ Air is capable of WPA2 wireless encryption for secure data transfer Buffalo Technology offers you a three year limited warranty on the Ministation™ Air.
Features and Benefits
  • Read and write files on Smart devices
  • Allow internet access during WiFi connection by using "Internet mode"
  • Battery charge anywhere with AC adapter or USB on PC
  • WiFi + superspeed USB 3.0 dual interface
  • Always together with Smart devices for additional storage
  • Easy WiFi setup connection with WPS and AOSS
  • WiFi connection with high security (WPA2)
  • Max simultaneous connection: 3 connections recommended
  • Number of Ports USB 3.0 x1
  • Format FAT32
  • Product Dimensions (WxHxD) 84 x 23 x 130 mm
  • Product Weight 285 g
  • Client OS Support (USB 3.0) Windows® 7 (32-bit/64-bit), Vista® (32-bit/64-bit), XP(32-bit), Mac OS X 10.5 or later
  • Client OS Support (WiFi) iOS 4.0 or later, Android 2.3 or later, 3.0 or later, 4.0 or later
  • App MiniStation Air
  • HDD 500 GB HDD
Contents
  • MiniStation Air
  • USB Cable
  • USB Power Cable
  • Quick Setup Guide
  • Warranty Statement
BUFFALO MiniStation Air - network drive - 500 GB
Network drive
Host Connectivity
USB 3.0 / 802.11b/g/n
Total Storage Capacity
500 GB
8.4 cm x 13 cm x 2.3 cm
285 g
Storage Controller
SATA USB 3.0
Hard Drive
1 x 500 GB
Radio access point 802.11b, 802.11g, 802.11n
Microsoft Windows XP, Apple MacOS X 10.5 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Apple iOS 4 or later, Android 2.3 or later
3 years warranty
Network drive
Host Connectivity
500 GB
8.4 cm
13 cm
2.3 cm
285 g
Storage Controller
SATA
Bus Type
SuperSpeed USB 3.0
Hard Drive
HDD
1 x 500 GB
Radio access point
Airstation OneTouch Secure System (AOSS), WPA2 encryption, Wi-Fi Protected Setup (WPS)
Encryption Algorithm
WPA2
1 x micro-USB 3.0 - Type B
1 x USB 3.0 cable , 1 x USB power cable
Run Time (Up To)
4 hours
3 years warranty
Service & Support Details
Limited warranty - 3 years
Accessories
C2G 4 port USB 3.0 SuperSpeed Hub
Quicklinx: 7CBW | In Stock
£68.29
C2G 2m USB 3.0 A Male to Micro B Male Cable
Quicklinx: 7GNS | In Stock
£6.87
Resources
The following resources are available for the Buffalo 500GB MiniStation Air USB 3.0 Mobile Wireless Storage
Scroll to top
