BT.com
Wishlist
Buffalo 4TB DriveStation USB 3.0 External Desktop Hard Drive
Delivery
Standard Due date unavailable
Buffalo's DriveStation USB 3.0 Hard Drive HD-LBU3 is the next generation of high speed external hard disk and offers SuperSpeed transfer speeds of up to 130MB/s, 3 times faster than USB 2.0. Backwards-compatible with all USB 2.0 enabled computers and notebooks, the DriveStation USB 3.0 is an easy to use external hard drive to add additional external storage to any device using a USB port. The DriveStation features a sleek, black glossy chassis that can be positioned vertically or horizontally, adapting to the location it is used in for an efficient use of space. An easy to use, economical and silent solution and with Auto installation and auto power on/off, you can quickly store, access, and transfer files, digital images, documents, and back-ups. Just plug it in to a PC or Mac and it works!
BUFFALO DriveStation USB 3.0 - hard drive - 4 TB - USB 3.0
Hard drive - external ( desktop )
4 TB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Enclosure Colour
Glossy black
3.9 cm x 18.9 cm x 12.3 cm
0.95 kg
2 years warranty
4 TB
USB 3.0
Internal Drive Interface
Serial ATA
3.9 cm
18.9 cm
12.3 cm
0.95 kg
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0
Power supply
AC 120/230 V ( 50/60 Hz )
Power Consumption
12 Watt ( active )
Software Included
Eco Manager, SecureLockMobile
Microsoft Windows XP, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Apple MacOS X 10.5 - 10.8
Enclosure Colour
Glossy black
2 years warranty
Service & Support Details
5 °C
35 °C
20 - 80% (non-condensing)
Scroll to top
