BT.com
Wishlist
Buffalo 3TB DriveStation Velocity USB 3.0 External HDD Hardware Encryption
Buffalo 3TB DriveStation Velocity...
£86.74
Select:
45 in stock
£86.74
Add to wishlist
Delivery
Standard 3-5 working days
SuperSpeed USB 3.0 hard disk drive
DriveStation™ Velocity is the perfect solution for those who need to transfer files quickly and easily. The amazing speed performance comes from a combination of a more efficient improved USB 3.0 interface, Buffalo's enhanced TurboPC EX data transfer and copy utility and a 7,200 RPM drive. With USB 3.0, digital content transfers at speeds of up to 5Gbps*. If you haven't moved up to USB 3.0 yet - DriveStation™ Velocity is backward compatible with USB 2.0.
The unit is also optimal for users who want to restrict access to their personal drive when on a shared computer or network. Powerful yet easy-to-use security options include automatic hardware encryption that protects your data, with no loss of performance.
Features and Benefits
  • SuperSpeed USB 3.0: The USB 3.0 interface moves data at rates of up to 5 gigabytes per second*, ideal for video and other dataintensive digital content
  • TurboPC EX utility: TurboPC EX adds more performance to Buffalo's TurboPC with TurboCopy performance and copy enhancement utility for Windows. Now saving, copying, and transferring files is even faster.
  • High speed 7,200 RPM hard disk: The disk reads and writes data faster, so you spend less time waiting when transferring and saving files
  • Hardware Disk Encryption: 256-bit AES Full Disk Encryption (FDE) protects your data from unauthorised access on Windows PCs
  • Back Up Your Files: Buffalo's Backup Utility automatically backs up your Windows PC, protecting your data
  • RAMDISK virtual disk utility: The Windows RAMDISK utility creates a small "virtual hard disk" using your computer's RAM (random access memory)
  • eco Manager: Eco minded power management tool for Windows regulates power usage, conserving energy and battery consumption
  • SuperEco: saves power consumption during stand-by mode by Auto Power OFF
  • SecureLock Manager: Easy software simplifies access for you while keeping others out on Windows PCs
  • Plug & Play Connectivity: Connecting and using the drive is simple-just plug it in to any USB port on a computer or other device you're connecting to. No need to install any drivers and no confusing settings.
  • Fully backwards compatible with USB 2.0: No adjustments are needed, just plug into any USB 2.0 port
  • 2-Year Warranty
BUFFALO DriveStation Velocity - hard drive - 3 TB - USB 3.0
Hard drive - external (desktop)
3 TB
Hardware Encryption
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Spindle Speed
7200 rpm
Hardware Full Disk Encryption (FDE), automatic backup, 256-bit AES
3.9 cm x 18.9 cm x 12.3 cm
0.95 kg
2 years warranty
3 TB
Hardware Encryption
USB 3.0
3.9 cm
18.9 cm
12.3 cm
0.95 kg
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x USB 3.0 - 9 pin USB Type A
Power supply
Power Consumption
18 Watt (active)
Software Included
Buffalo Tools
Microsoft Windows XP, Microsoft Windows 7, Apple MacOS X 10.4 or later, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (32/64 bits)
Plug and Play
2 years warranty
5 °C
35 °C
20 - 80% (non-condensing)
Accessories
C2G 4 port USB 3.0 SuperSpeed Hub
Quicklinx: 7CBW | In Stock
£68.29
C2G 2m USB 3.0 A Male to Micro B Male Cable
Quicklinx: 7GNS | In Stock
£6.87
Resources
The following resources are available for the Buffalo 3TB DriveStation Velocity USB 3.0 External HDD Hardware Encryption
Scroll to top
